Avidcnc retrofit Mesa 7192H
- Fastfred
07 Jan 2022 19:39 #231047
by Fastfred
Avidcnc retrofit Mesa 7192H was created by Fastfred
Hi need advice just purchased my first cnc (avidcnc) and with the plug and play eletronics at the moment its setup up for Mach4 but havent purchaesed it .Was interested in switching over to linuxcnc , I contacted Mesa through email but not getting any detail info but was told to use the 7192H so I can keep the BOB thats included without doing any rewiring .Any help advice would be really appreciated on how and what info I need ?
Thanks Fred
Thanks Fred
- Thank you received: 7468
07 Jan 2022 21:29 #231059
Replied by tommylight on topic Avidcnc retrofit Mesa 7192H
Pictures of connectors ???
- Fastfred
08 Jan 2022 02:40 #231090
by Fastfred
Replied by Fastfred on topic Avidcnc retrofit Mesa 7192H
- Fastfred
09 Jan 2022 06:12 #231220
by Fastfred
Purchased the 7192H Peter at Mesa sent me bitfile to work with the Bob, but unfortunately trying to find information how to load it to linuxcnc.
09 Jan 2022 09:25 #231226
Read the 7i92 manual and replace the .bit file name to the name of the bit file PCW sent you:
forum.linuxcnc.org/30-cnc-machines/44700...ofit?start=10#231041
- Fastfred
11 Jan 2022 18:08 #231464
by Fastfred
Trying to connect to mesa card .
Tried mesaflash--device 7i92--addr 10.10.10.10--reached
Command not found
Command not found
- D.L.
- Thank you received: 37
11 Jan 2022 18:22 #231465
by D.L.
Replied by D.L. on topic Avidcnc retrofit Mesa 7192H
mesaflash --device 7I92 --addr 10.10.10.10 --readhmid
mesaflash --device 7I92 --addr 10.10.10.10 --verbosePlease Log in or Create an account to join the conversation.
- Fastfred
11 Jan 2022 18:48 #231468
by Fastfred
I tried few times no luck
I typed ping 10.10.10.10 it connects if that means anything.
- arvidb
- Thank you received: 158
11 Jan 2022 18:51 #231470
by arvidb
Replied by arvidb on topic Avidcnc retrofit Mesa 7192H
I'm not sure mesaflash is installed by default (though it probably should be). You might need to download it manually. Do a search for mesaflash here on the forum and you should be able to find instructions.
- Thank you received: 5321
11 Jan 2022 18:58 #231471
Replied by PCW on topic Avidcnc retrofit Mesa 7192H
I thought mesaflash was included with LinuxCNC, but if not, its here:
github.com/LinuxCNC/mesaflash
You can install it with the quickstart instructions at the bottom of the page.
(note, you don't need to type these commands in, you can copy/paste
the commands into a terminal windows one at a time)
Time to create page: 0.150 seconds
