Avidcnc retrofit Mesa 7192H
23 Jan 2022 00:47 - 23 Jan 2022 00:47 #232848 by PCW
Replied by PCW on topic Avidcnc retrofit Mesa 7192H
You will need to set the actual number of stepgens (3?) and PWMGens (1)
in pncconf.
The stepgen and PWMGen pinout will be correct because the firmware is made
for your breakout. The only possible issue with using mis-matched pncconf firmware
is GPIO setting but there may in fact be no conflict except possibly the PWM pin.
Last edit: 23 Jan 2022 00:47 by PCW.
  • Fastfred
  • Senior Member
  • Senior Member
23 Jan 2022 01:01 #232851 by Fastfred
Replied by Fastfred on topic Avidcnc retrofit Mesa 7192H
If I am thinking correctly if I plug in the mesa card I should get some kind of movement ?
23 Jan 2022 01:19 #232854 by PCW
If you create a hal/ini file with pncconf with the correct axis <--> stepgen mapping
and correct step timings, yes you should be able to get motion, but be careful
because things like limit switches are not likely to work so be ready to shut down
to avoid a possible crash.
  • Fastfred
  • Senior Member
  • Senior Member
23 Jan 2022 22:50 #232903 by Fastfred
Everything plugged in getting the estop led light on the BOB stays on with pc plugged in or not, not sure what I did wrong? already having hard time figuring out the pin locations.
23 Jan 2022 22:57 #232904 by PCW
That's probably expected until you setup the GPIO pin that drives the BOB's
EStop pin _and_ its polarity
  • Fastfred
  • Senior Member
  • Senior Member
27 Jan 2022 19:02 #233300 by Fastfred
Thought I did it correctly?
File Name: linuxcnc.report.pdf
File Size:6 KB
  • Fastfred
  • Senior Member
  • Senior Member
27 Jan 2022 20:33 #233306 by Fastfred
If reading this correctly I have the wrong kernel.
27 Jan 2022 20:55 #233310 by PCW
I cannot read the pdf
what does the command:
uname -a
report?
  • Fastfred
  • Senior Member
  • Senior Member
27 Jan 2022 21:11 #233312 by Fastfred
Linux debian 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
27 Jan 2022 21:22 #233314 by PCW
Yes, that's the wrong kernel for Mesa Ethernet cards
www.linuxcnc.org/iso/linuxcnc-2.8.2-buster.iso
Is the correct distribution
Time to create page: 0.135 seconds
