7i96 Probe Problem
15 Mar 2022 14:17 #237329 by imslo
Replied by imslo on topic 7i96 Probe Problem
I hooked my probe up to my old system and it worked fine just as it has for several years. I think maybe the differences in the system maybe the problem. Old system is Dell Optiplex 755 built in 2008, dual core 1.8 ghz, 2 gb ram. New system dell i7-7700 3.6ghz 16 gb ram. It looks to me like the new system is so fast it is picking up bounce where the old system was so slow it didn't see it. There is one difference in the hookups. My motors are have six wire and came from hobbycnc. On the old system all six wire were hooked up on a hobbycnc chopper board. I am now running on four wires with tb6600 drivers. Can you point me toward a debouncing tutorial?
15 Mar 2022 14:22 #237330 by imslo
I am running Stretch with 2.9 cnc on the old system. On the new is Buster with cnc 2.8.
15 Mar 2022 14:49 #237335 by PCW
Replied by PCW on topic 7i96 Probe Problem
Its seems more likely that there is a difference in probe handling
between LinuxCNC versions 2.8 and 2.9
A single debounce component would be setup like:
loadrt debounce cfg=1
addf  debounce.0 servo-thread
setp debounce.0.delay 10
net raw_probe hm2_7i96.0.gpioXXXX debounce.0.in
net probe_in debounce.0.out motion.probe-input
15 Mar 2022 15:00 #237336 by imslo
Probe worked on Linuxcnc version 2.9, 2.8, 2.7 and probably 2.6 on the old system. Should I try to install 2.9. I have no idea where what you show above goes.
15 Mar 2022 15:45 #237338 by PCW
They can go anywhere in the hal file (but you need to change the existing connections)
15 Mar 2022 16:09 #237340 by imslo
I put it at the beginning of the file and I am still getting the error. I changed
to:
net raw_probe hm2_7i96.0.gpio0001 debounce.0.in
Is that the right syntax?
15 Mar 2022 16:23 #237343 by imslo
Correction on last post.
The changes were not saved because I did not use sudo.
I did save the changes and Linuxcnc would not run.
  • Moderator
  • Moderator
15 Mar 2022 17:16 #237349 by tommylight
Replied by tommylight on topic 7i96 Probe Problem
Shoudl probably be
net raw_probe hm2_7i96.0.gpio001 debounce.0.in
15 Mar 2022 19:48 #237364 by imslo
I put this in my Custom Hal file and no matter what I call the pin linuxcnc will not run and I get this error: ./custom.hal:7: Pin 'hm2/7i96.0.gpio001' does not exist. I have called it 0001, 001, .001 so anything I call it does not work.
15 Mar 2022 19:53 #237365 by rodw
Replied by rodw on topic 7i96 Probe Problem
comment the broken  line out, open linuxcnc and halshow, review the pin name to get the correct name and edit your hal file
Time to create page: 0.270 seconds
