7i96 Probe Problem
15 Mar 2022 20:41 #237373 by imslo
Replied by imslo on topic 7i96 Probe Problem
Hal shows this: hm2_7i96.0.gpio.001.in
When I use the above iI get this error: Pin 'hm2_7i96.0.gpio.001.in' was already linked to signal 'probe-in'
When I change anything about the pin name I get this error: Pin 'hm2_7i96.0.gpio.001' does not exist
15 Mar 2022 21:17 - 15 Mar 2022 21:17 #237381 by PCW
Replied by PCW on topic 7i96 Probe Problem
Yes, you must disconnect the old connection between probe_in and
hm2_7i96.0.gpio.001.in because hm2_7i96.0.gpio.001.in now needs
to connect to the debounce input (and the raw probe input signal)
Last edit: 15 Mar 2022 21:17 by PCW.
15 Mar 2022 22:04 #237392 by imslo
I don't understand. How does the probe hook up now?
15 Mar 2022 22:24 #237396 by PCW
In HAL, without debounce, it connects directly from the hardware
input pin (hm2_7i96.0.gpio.001.in) to LinuxCNC's motion.probe-input
pin, probably via 2 statements:
net probe-in hm2_7i96.0.gpio.001.in
net probe-in motion.probe-input
These need to be replaced with connections  that insert the
debounce component between the raw signal from the hardware
and LinuxCNC's motion.probe-input pin:
net raw- probe-in hm2_7i96.0.gpio.001.in => debounce.0.in
net probe-in debounce.0.out =>  motion.probe-input
15 Mar 2022 22:27 #237397 by imslo
YeeHaw seems to be working. In my config file I set pin 01 to unused and inserted the following in my custom Hal file:
loadrt debounce cfg=1
addf debounce.0 servo-thread
setp debounce.0.delay 10
net raw_probe hm2_7i96.0.gpio.001.in
Thank you for sticking with me. I was about ready to abound the project.
16 Mar 2022 14:25 #237470 by imslo
Last post:
Above did not work. This is working after what seems like several hundred tests.
net debounce-probe-in debounce.0.0.in <= hm2_7i96.0.gpio.001.in
net probe-in debounce.0.0.out => motion.probe-input
16 Mar 2022 15:03 #237471 by PCW
Right, the raw probe signal needs to be fed
through the debounce function.
13 Sep 2024 21:39 #310104 by CCCNC
Replied by CCCNC on topic 7i96 Probe Problem
Thank you!
This helped me a lot, I now have consistent probe result. Thanks to debouncing there is no more "Probe tripped during non-probe move".
Let´s make some chips! :-)
/T
Time to create page: 0.305 seconds
