ATC Project - Debug phase
4 years 5 months ago #243804 by andypugh
Replied by andypugh on topic ATC Project - Debug phase
Hmm, that looks like a bug in the GUI code, rather than a misconfig on your part.
Is the problem with qtvcp or qtpyvcp?
4 years 5 months ago #243807 by spumco
Replied by spumco on topic ATC Project - Debug phase
Issue is with qtvcp.
I have not tried to install qtpyvcp - that's the next step once we establish I didn't mess anything up thus far.  Didn't want to color too far outside the lines without adult supervision.
4 years 5 months ago #243808 by andypugh
So, which GUI in particular are you using? Perhaps someone else using the Bookworm packages can try it out.
At this point, perhaps is it worth making a backup of the HDD?
(My next suggestion is going to involve grabbing and attempting to install the Buster packages. It would be good to have a route back to here)
4 years 5 months ago #243816 by spumco
My preference is Probe Basic.  That's what I've been working with since day 1, and while I've run other GUIs as sims I haven't connected my machine up using a different GUI.
Having said that, I would like to try the vertical/portrait version of qtvcp-Woodpecker that was posted here late last year.  My ultimate goal is to have a vertical GUI... and the PB developers have their hands full with the py2 to py3 thing.  The PB-Vertical version is likely a long time off.
4 years 5 months ago #243828 by andypugh
I was actually asking which GUI crashed on you.
Also: I don't know which version of Carousel you will have got from the Bookworm repository but from the package name
2.9.0~pre0+git20220402.2500863908-4
I am guessing the 2nd of April build, which still has a buggy carousel.
It should be safe (ish) to grab this .deb package:
buildbot.linuxcnc.org/dists/buster/maste...g433a36711_amd64.deb
Which is the latest version, though built for Buster against a different kernel.
If it doesn't work then re-installing LinuxCNC from the Bookworm repository ought to be relatively easy.
to use the .deb..
sudo dpkg --install linuxcnc-uspace_2.9.0~pre0.6521.g433a36711_amd64.deb
And, basically, see what happens....
4 years 5 months ago - 4 years 5 months ago #243839 by spumco
Sorry, misunderstood the question.  qtdragon_hd is what caued the fault in the report, but all qtvcp sims cause the same fault.
Have tried blender, qtdragon, qtaxis - all the same error.
gscreen errors out (ImportError: cannot import name Vte, introspection typelib not found)
pyvcp works, no errors.
glade works, no errors.
EDIT - downloaded the .deb and ran the dpkg you posted.  Error report:
mill@debian:~/Downloads$ sudo dpkg --install linuxcnc-uspace_2.9.0~pre0.6521.g433a36711_amd64.deb
(Reading database ... 150854 files and directories currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.0~pre0.6521.g433a36711_amd64.deb ...
Unpacking linuxcnc-uspace (1:2.9.0~pre0.6521.g433a36711) over (2.9.0~pre0+git20220402.2500863908-4) ...
dpkg: dependency problems prevent configuration of linuxcnc-uspace:
 linuxcnc-uspace depends on python3 (<< 3.8); however:
  Version of python3 on system is 3.10.4-1+b1.
 linuxcnc-uspace depends on libboost-python1.67.0; however:
  Package libboost-python1.67.0 is not installed.
 linuxcnc-uspace depends on libgdk-pixbuf2.0-0 (>= 2.22.0); however:
  Package libgdk-pixbuf2.0-0 is not installed.
 linuxcnc-uspace depends on libpython3.7 (>= 3.7.0); however:
  Package libpython3.7 is not installed.
 linuxcnc-uspace depends on libreadline5 (>= 5.2); however:
  Package libreadline5 is not installed.
dpkg: error processing package linuxcnc-uspace (--install):
 dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.33-7) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for shared-mime-info (2.2-1) ...
Errors were encountered while processing:
 linuxcnc-uspace
Last edit: 4 years 5 months ago by spumco.
Time to create page: 0.813 seconds
