ATC Project - Debug phase
4 years 5 months ago #243520
Replied by andypugh on topic ATC Project - Debug phase
I just pushed an update to 2.8 and master.
It's building the 2.8 debs as I write this, the master/2.9 debs should follow after that process has finished.
But, as you are building from source, the update.sh script that you have should build with the bugfix.
- spumco
- Thank you received: 905
4 years 5 months ago #243521
by spumco
Replied by spumco on topic ATC Project - Debug phase
Thanks Tommy. Navigating to the folder and adding the ./ seems to get it working.
Still got an error - just seeing if it worked - but at least it's responding.
I've attached a screenshot of the catfish search results. Would you mind having a look and seeing if it looks like I've got multiple installations or some other new user screwup? While I'm starting to pick up on LCNC a little, Linux is still driving me crazy.
Andy - the update.sh script is the one from the github site I downloaded, right?
- spumco
4 years 5 months ago #243522
by spumco
Ran the updater script.
- Thank you received: 7491
4 years 5 months ago #243524
Replied by tommylight on topic ATC Project - Debug phase
FIY, next time you install Debian, when it asks for RooT password just click next.
You are running as root on a Linux box, most user software is made to be used as a user not an admin(root in Linux).
- spumco
4 years 5 months ago #243526
by spumco
Thanks Tommy. I thought I did this during the install (clicked next, no root PW entered)
Should I reinstall Debian from scratch, or is there something else I should do to correct this?
I've lost count how many times I've wiped & reinstalled variations of Linux over the past year of trying LCNC, so at this point I don't care about doing it again if it means future problems are avoided.
- spumco
4 years 5 months ago #243530
by spumco
Since I was having problems running the updater, I thought I'd have a go at just hand-editing carousel.comp to match the change in the github update.
Behavior is unchanged. This may mean nothing, since I don't know what I'm doing and editing the comp that way doesn't change how LCNC functions... but I figured I'd mention it. If that was dumb, let me know and I'll change it back (or do some other Linux gymnastics if needed).
Time to create page: 0.279 seconds
