ATC Project - Debug phase
4 years 5 months ago - 4 years 5 months ago #243125 by spumco
Replied by spumco on topic ATC Project - Debug phase
UPDATE
[didn't want to edit the last and hose up the formatting]
carousel.0.jog-fwd seems to work.
carousel.0.jog-rev rotates the carousel in the same direction.
I stopped it in a random spot (after carousel.0.enable) with M65 P0.  I then set jog-fwd to high in hal-show and it moved forward to the next pin.
carousel.0.current-position counted up (Yay!)
Clearing jog-fwd and setting jog-rev cause the carousel to rotate in the same direction and stop at the next pin.  Current position went DOWN by one increment.
loadrt carousel  pockets=18 encoding=index num_sense=18 dir=2 (means it should be bi-directional, right?)
This motor & drive was working fine (CW/CCW) as my A-axis until recently, so no hardware concerns.
So carousel.comp is moving and counting up and down, but the motor is only rotating one direction.
Looks like I've got a stepgen config issue.  Unless carousel.0.rev-dc needs to be a negative number?
Anything obvious come to mind?
Why yes, in fact, carousel.0.rev-dc DOES need to be a negative number.  Ignore the above...
Still have an issue with the homing - keep rotating indefinately until I kill it with an M65 P0.
Last edit: 4 years 5 months ago by spumco. Reason: Eureka!
4 years 5 months ago #243126 by spumco
4 years 5 months ago #243169 by andypugh
Replied by andypugh on topic ATC Project - Debug phase
Looking at the code, it shouldn't...
What is the "state" pin showing in this scenario? Does the "homed" pin set?
4 years 5 months ago #243170 by andypugh
Actually, this should be a fixed bug, but might not have been released yet.
Download this file:
raw.githubusercontent.com/LinuxCNC/linux...onents/carousel.comp
then issue the command
sudo halcompile --install carousel.comp
and see if that fixes the behaviour
4 years 5 months ago #243177 by spumco
Thanks Andy, I'll try the new comp file tonight.
Regarding the homed & state pins... they weren't in halshow.  That was the first (maybe second) thing I thought to check while debugging, but that pin didn't exist under carousel in halshow.
carousel.0.state
carousel.0.homed
carousel.0.homing
are all missing from available pins in halshow -> carousel
carousel.0.timer was present.
4 years 5 months ago #243208 by spumco
sudo: halcompile: command not found
Linux is making me feel dumb again.
Time to create page: 0.220 seconds
