How to install VNC on LinuxCNC 2.9 with QTplasmac?
4 years 5 months ago #243159 by rodw
I'm just heading for bed. Use halshow to display the ohmicsense pins.
Watch the voltage when contacting the plate. It should go to about 24 volts. Look at the thresholds and make sure the high threshold is <  the contact voltage
Observe in halscope if you really get stuck.
4 years 5 months ago #243215 by LinfieldGarage
Thanks Rod,
Here is a short video of HALSHOW.  First I shorted the ohmic wires 3 times, watch the volts and encoder.Second I hit the Ohmic Test button 3 times.  Watch the ohmic-enable and ohmicsense.is-probing signals. The Z-axis never moves and the ohmic sensor light never comes on.
I have followed as many config file examples as I can find, I am thinking the ohmic3 component isn't working or I am missing a config somewhere.
Thanks again!
4 years 5 months ago #243248 by rodw
what pin do you have connected to ohmicsense.is_probing?
It needs to be true when probing (from plasmac probe enable).
I see it going true but its not true when ohmicsense.ohmic-volts is 24 volts which is when the probe is touching the plate.
4 years 5 months ago #243269 by LinfieldGarage
I wish I understood all of the relationships of the signals better, here is what my spaceship.hal has today:
would you be willing to post your full hal and ini configs for me to review? Our machines are very similar.
loadrt ohmic3 names=ohmicsense
addf ohmicsense servo-thread
# --- 7i96 ENCODER SETUP FOR OHMIC SENSING---
setp hm2_7i96.0.encoder.01.counter-mode 1
setp hm2_7i96.0.encoder.01.scale -1
setp ohmicsense.thcad-0-volt-freq 138000
setp ohmicsense.thcad-max-volt-freq 966100
setp ohmicsense.thcad-divide 32
setp ohmicsense.thcad-fullscale 5
setp ohmicsense.volt-divider 4.9
setp ohmicsense.ohmic-threshold 22
setp ohmicsense.ohmic-low 21.5
setp ohmicsense.mode 1
setp ohmicsense.num-readings 10
# --- 7i76e ENCODER SETUP FOR OHMIC SENSING---
net ohmic-vel ohmicsense.velocity-in <= hm2_7i96.0.encoder.01.velocity
net plasmac:ohmic-probe <= ohmicsense.ohmic-on
net plasmac:ohmic-enable => ohmicsense.is-probing
net plasmac:motion-type => ohmicsense.motion-type-in
Time to create page: 0.229 seconds
