How to install VNC on LinuxCNC 2.9 with QTplasmac?
4 years 5 months ago #242478 by LinfieldGarage
That fits my workflow exactly. This machine will replace a smaller plasma running Mach4, so Samba will be very useful. I saw the “load latest” button in your YouTube video. That’s a cool idea.
4 years 5 months ago #242525 by rodw
With SAMBA, I can't remember exactly what, but  in Windows there was a setting that needed to be enabled to allow Windows to talk to the linux  drive. Good luck. I tried for years to do this, Now I've forgotten how...
4 years 5 months ago #242628 by LinfieldGarage
Hehe, thanks. I'll let you know how that goes. I got my laser crosshairs and offsets working, next up is the THCAD-5 Ohmic sensing, then some fine tuning before this machine runs well enough to use.
4 years 5 months ago #242672 by rodw
You might find this useful. It contains my latest config for THCAD-5 ohmic sensing
I just load the supplied hal file from my in file. It will need editing to suit your config.
You need to select the ohmic-on pin as your ohmic probe pin when congiguring qtplasmac.
to build the component
sudo halcompile --install  ohmic3.comp
4 years 5 months ago #242699 by LinfieldGarage
Thanks Rod, this is a big help. I got my 7i96 flashed today with the new code, and received my new THCAD on Monday. I’ll likely try to put the ohmic kit together tomorrow.
I’ll check out your code tomorrow as well.
Thanks again!
4 years 5 months ago #243114 by LinfieldGarage
Hey Rod,
I have been messing with this for way too long but cannot get the Ohmic test button in Qtplasmac to do much. It triggers the relay to light up the 24 volt power supply but nothing else happens.
I think I am close because can see voltage on encoder.01 and it changes drastically when connect the ohmic wire to the table. I customized and loaded the ohmic3 component as described above.
Could you please look at my files and comment? Thank you in advance.
