- LinuxCNC
- General LinuxCNC Questions
- hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
- Thank you received: 4652
07 May 2022 21:09 #242258
Replied by andypugh on topic hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
Yes, it does sound like a good fit for for a 7i49.
The following user(s) said Thank You: smc.collins
- smc.collins
- Thank you received: 139
07 May 2022 21:59 - 07 May 2022 22:00 #242273
by smc.collins
Replied by smc.collins on topic hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
I need a TON of IO, whats the best board to pair with the 7i49 ? I have a 5I25 and 7i76D sitting here, but I am willing to grab another board if need be
Last edit: 07 May 2022 22:00 by smc.collins.
08 May 2022 00:19 #242279
The 7i49 belongs to a different class of boards to the 7i76. (it uses a 50 pin connector rather than the 25 pin D-sub)
It might be possible to use a 7i49 with a 5i25 and an adaptor. But when faced with the same quandry for my lathe the choice was
5i24
7i49
7i44 -> 7i84 + 2 x 8i20 + 7i73
That leaves a whole header free on the 5i24.
Rather than 7i44 + smart serial you could use 1x or 2x 7i37 / 7i37TA but I needed smart-serial for the 8i20 drives so went with that for all IO.
5i24
7i49
- smc.collins
08 May 2022 01:45 - 08 May 2022 04:35 #242283
by smc.collins
My drives are velocity 10v, so good there with 7i49 OTOMH i need bare min 48 channels of io sit up 24in by 24 out, I plan to add a opto coupled solid state relay control board in between to handle any goofy 120v switching, of which I have a lot.
Looking at the 7i49, there is the 7i49 and the 7i49hv, what is the difference between these cards ?
Last edit: 08 May 2022 04:35 by smc.collins.
08 May 2022 15:36 #242305
I don't know. I have looked, and I am still not sure.
I found a reference to the HV on the forum:
forum.linuxcnc.org/forum/30-cnc-machines...-the-way/29214#29214
I think this is a question for PCW / Mesa
If you need lots of IO, and in various voltages and current ratings, then I would suggest smart-serial IO in a 7i44. Then you can mix-and-match up to 16 of these boards: store.mesanet.com/index.php?route=product/category&path=83_88
- smc.collins
08 May 2022 15:57 - 08 May 2022 16:00 #242308
by smc.collins
to make sure understand the ladder of hardware involved.
In PC on PCI slot
5i24 head at pci
7i49 slave to 5i24 50pin
7i44 slave to 5i24 50pin
Connected from 50pin 5i24
7i44 serial head cat5 rs serial
connected via Serial
7i84d serial slave cat5 I might need 2 of these
7i73 serial slave cat5
How complicated is the configuration of the HAL component to get all of this to work ?
In PC on PCI slot
5i24 head at pci
Last edit: 08 May 2022 16:00 by smc.collins.
08 May 2022 16:13 #242310
But I think we need to know more about the motors and drives.
Are they brushless or brushed servos? Do the drives currently have any feedback from the motors?
Probably very simple.How complicated is the configuration of the HAL component to get all of this to work ?
- smc.collins
08 May 2022 19:31 #242319
by smc.collins
Things I can say with certainty, I also posted the 25 pages of schematics but I will do it again here.
Servos are brushed
Servos have Tach feedback, to servo drives AFAICT
The actual resolver and servo wiring is fairly straight forward, However I do plan to test everything end to end to ensure that the schematics are correct and any oddities in the wiring are made complaint with the MESA hardware.
My biggest concern is tuning the servos and resolvers, I am sure I can get them working relatively easily enough.
these are 2 separate sets of the same prints, some pages in each set scanned better, I have not had time to go through and fully update them, as I am gutting my machine it seems rather pointless. But if anyone ever needs a set of 1980 cinturn 12u prints, here's a complete set
drive.google.com/file/d/1BGFrK_5f8lrwg6d..._5T/view?usp=sharing
drive.google.com/file/d/1FgP3BYVFzbULthE...H-Q/view?usp=sharing
Servos are brushed
08 May 2022 23:33 #242334
There are two suitable bitfiles in the standard 5i24 (and also 5i23 and many other) card firmware sets.
OK, in that case I would expect the configuration to be relatively easy. PnCConf does not appear to know about the 5i24 or the 7i49, which complicates matters a little. I would suggest making a 5i23 + 7i33 configuration, then posting it here and I will convert it over (I have the matching hardware so can crosscheck the pin names). This is mainly just swapping encoder to resolver with search and replace..Servos are brushed
- smc.collins
08 May 2022 23:43 - 09 May 2022 02:39 #242335
by smc.collins
I appreciate the help, I think I can get by with a single IO card, but I am double checking. Looks like I should get 2 IO cards, due to all the input, and MESA is out of stock on the 7i33 input cards, which is what I'd want my extra IO for. I figure I can just use a 7i84d for the extra IO for the control panel, and I have LED light and stuff I would like to run including a foot pedal to operate the chuck
Last edit: 09 May 2022 02:39 by smc.collins.
- LinuxCNC
Time to create page: 0.123 seconds
