- LinuxCNC
- General LinuxCNC Questions
- hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
- JR1050
- Thank you received: 31
31 May 2022 18:50 #244304
by JR1050
Replied by JR1050 on topic hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
Are the tachs mounted on the motors or on the screw ? Tachs should go to the drive, they are velocity feedback.
The four switch’s will represent a number based on which switch is actuated . Each switch will represent a weighted bit. From right to left.
True. False. Decimal
Switch one. 1. 0. 1
Two. 1. 0. 2
Three. 1. 0. 4
Four. 1. 0. 8
0110 = 6
1000=. 8
0011=. 3
Ect
Use wsum to convert the weighted bits to a decimal.
Switch one. 1. 0. 1
Two. 1. 0. 2
Three. 1. 0. 4
Four. 1. 0. 8
0110 = 6
1000=. 8
0011=. 3
Ect
- smc.collins
- Thank you received: 139
31 May 2022 22:28 #244314
by smc.collins
Replied by smc.collins on topic hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
Tachs are mounted on the motors and directly connected to the Arcamatic drives.
I am using a 7i97 and a serial connected 7i76 for additional IO. I may grab a few of those other modules for use on the pendant controls, Mesa is out of 7i73 afaict
- JR1050
31 May 2022 23:00 - 31 May 2022 23:31 #244318
by JR1050
Seems like a 7i76 is a step and direction card. Your drives are gonna be analog. I wanna say you need a 7i77 for analog drives. I may be wrong about that...
I have a 7i73, brand new , never used. Sell it to you for what ever the going rate is. I use 7i84 for panels , I like the terminal blocks.
Last edit: 31 May 2022 23:31 by JR1050.
- Thank you received: 7468
31 May 2022 23:01 - 31 May 2022 23:07 #244319
Replied by tommylight on topic hydraulic motor lathe turret, keep switches or switch to rotary encoder ?
Also out of stock in USA
mesaus.com/product/7i73/
But in stock in Portugal
eusurplus.com/index.php?route=product/pr..._61_74&product_id=96
Edit
Mesa 7i84 can be used for panels also, but no LCD support and limited resolution on analog inputs, 4 of them.
It does do 2 MPG though.
Edit
Last edit: 31 May 2022 23:07 by tommylight. Reason: more info
- smc.collins
01 Jun 2022 12:25 #244366
by smc.collins
the 7i97 will handle all of the analog 0-10v controls, the 7i76 is just there for IO, I already had it on hand and the machine I was going to use it on was scrapped after I gutted it for parts. I also have a set of steppers and stepper drivers and I might use them for things like pressure control etc later. I very well may put a stepper on the turret drive and remove the hydraulic motor, I doubt it, but I have options now.
- smc.collins
01 Jun 2022 12:26 #244368
by smc.collins
I may use the 7i84, I do not need a lcd, I have a 24 inch touch screen monitor that's being put on the machine. I would however like to use the factory control panels with some changes.
- LinuxCNC
Time to create page: 0.146 seconds
