Attached parallel board to breakout board can't open up linuxcnc anymore
4 years 2 months ago #250264 by Routerworks
I had bought and installed a parallel board (no drivers) and was able to set up and use linuxcnc wizard no problems.  I then attached the parallel port to a breakout board (new) and it all went south.I am attaching the report.No idea what to do.Thanks for any help
4 years 2 months ago #250265 by Routerworks
4 years 2 months ago #250266 by Routerworks
File Name: linuxcncreport.txt
File Size:6.57 KB
4 years 2 months ago #250283 by JT
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko: No such device
Looks like the parallel port is not found.
JT
4 years 2 months ago #250284 by probamo
I had issue as well, kernel less then 4 does not recognize attached boards. Install kernel 4.xx and higher then you'll get recognize you parport card.
4 years 2 months ago - 4 years 2 months ago #250288 by Bari
What do you mean by installed? Pushed into the PCI/e slot or?
Were you able to test the card using Stepconf with the BOB attached to a stepper motor and driver?
Last edit: 4 years 2 months ago by Bari. Reason: spelling
Time to create page: 0.464 seconds
