- LinuxCNC
- General LinuxCNC Questions
- Attached parallel board to breakout board can't open up linuxcnc anymore
- Routerworks
- Thank you received: 14
25 Aug 2022 09:38 #250406
by Routerworks
Replied by Routerworks on topic Attached parallel board to breakout board can't open up linuxcnc anymore
also got this with lspci -v
04:09.0 Communication controller: MosChip Semiconductor Technology Ltd. PCI 9815 Multi-I/O Controller (rev ff) (prog-if ff)
!!! Unknown header type 7f
Kernel modules: parport_pc
- Routerworks
25 Aug 2022 12:31 #250417
by Routerworks
Also pictures
- Thank you received: 7504
25 Aug 2022 13:40 #250431
Replied by tommylight on topic Attached parallel board to breakout board can't open up linuxcnc anymore
Where is the crystal ???
The results of lspci do not show address in use, not ok, but does show the parport driver is in use.
It also shows and error that i have never seen before, so looking at your picture, where is the crystal?
It should be located where the big coper plate is, be it a small round metal tube or a bigger flat one.
Not exactly sure if all those boards have it though, but i am sure all the ones i used have it, the difference being yours looks like 2 parallel ports while mine are single parallel with 2 of RS232.
25 Aug 2022 13:43 #250432
Looking at the picture again, it sure looks as the crystal was removed by pulling it away from the parallel port, marks on holes have a slope.
- Routerworks
25 Aug 2022 14:06 #250437
by Routerworks
Think I'll have to go back to the computer store that sold me this board and see what they say. Sounds fishy to me.
thanks
thanks
- Bari
- Thank you received: 234
25 Aug 2022 16:32 #250461
by Bari
Replied by Bari on topic Attached parallel board to breakout board can't open up linuxcnc anymore
MCS9815CV datasheet datasheet.datasheetarchive.com/originals...et-1/sf-00037687.pdf
i.ebayimg.com/images/g/Tl8AAOSwNLthoOP9/s-l1600.jpg
It can use the PCI bus clock vs the crystal.
Might be a bad board or really oxidized PCI slot contacts. The MB looks pretty old and dirty. You could try inserting and removing the card a few times or using a little bit of no residue contact cleaner on the socket if the problem is oxidized contacts.
- Routerworks
25 Aug 2022 19:05 #250477
by Routerworks
Looks like it might be working. I tried cleaning and pulling the card in and out a few times then rebooted. Now I am getting responses. Also when I turned the computer on I heard the relay on the breakout board click. Below are all the responses to the different terminal commands everyone suggested. Now they are returning messages. Your interpretation would be greatly appreciated.
laurence@Router1:~$ cat /proc/ioports | grep parport
0000-0000 : parport1
0000-0000 : parport0
laurence@Router1:~$ sudo ispci -v |grep par
[sudo] password for laurence:
sudo: ispci: command not found
laurence@Router1:~$ sudo lspci -v | grep par
Subsystem: LSI Logic / Symbios Logic 2P0S (2 port parallel adaptor)
Kernel driver in use: parport_pc
laurence@Router1:~$ sudo lspci -vvxx
00:00.0 RAM memory: NVIDIA Corporation C51 Host Bridge (rev a2)
Subsystem: NVIDIA Corporation C51 Host Bridge
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
Capabilities: [44] HyperTransport: Slave or Primary Interface
Command: BaseUnitID=0 UnitCnt=15 MastHost- DefDir- DUL-
Link Control 0: CFlE+ CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config 0: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=16bit DwFcInEn- LWO=16bit DwFcOutEn-
Link Control 1: CFlE+ CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn+ ExtCTL- 64b-
Link Config 1: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Revision ID: 1.03
Link Frequency 0: 1.0GHz
Link Error 0: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability 0: 200MHz+ 300MHz+ 400MHz+ 500MHz+ 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Feature Capability: IsocFC+ LDTSTOP+ CRCTM- ECTLT- 64bA- UIDRD-
Link Frequency 1: 800MHz
Link Error 1: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability 1: 200MHz+ 300MHz+ 400MHz+ 500MHz+ 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Error Handling: PFlE+ OFlE+ PFE- OFE- EOCFE- RFE- CRCFE- SERRFE- CF- RE- PNFE- ONFE- EOCNFE- RNFE- CRCNFE- SERRNFE-
Prefetchable memory behind bridge Upper: 00-00
Bus Number: 00
Capabilities: [e0] HyperTransport: MSI Mapping Enable+ Fixed-
Mapping Address Base: 00000000fee00000
00: de 10 f0 02 06 00 b0 00 a2 00 00 05 00 00 80 00
10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 f0 02
30: 00 00 00 00 44 00 00 00 00 00 00 00 ff 00 00 00
00:00.1 RAM memory: NVIDIA Corporation C51 Memory Controller 0 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 0
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00: de 10 fa 02 00 01 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 fa 02
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00:00.2 RAM memory: NVIDIA Corporation C51 Memory Controller 1 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 1
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
NUMA node: 0
00: de 10 fe 02 00 00 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 fe 02
00:00.3 RAM memory: NVIDIA Corporation C51 Memory Controller 5 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 5
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00: de 10 f8 02 00 00 a0 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 f8 02
30: 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00
00:00.4 RAM memory: NVIDIA Corporation C51 Memory Controller 4 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 4
Latency: 0
NUMA node: 0
00: de 10 f9 02 06 00 a0 00 a2 00 00 05 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 f9 02
00:00.5 RAM memory: NVIDIA Corporation C51 Host Bridge (rev a2)
Latency: 0
NUMA node: 0
Capabilities: [44] #00 [00fe]
Capabilities: [fc] #00 [0000]
00: de 10 ff 02 06 00 b0 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 ff 02
00:00.6 RAM memory: NVIDIA Corporation C51 Memory Controller 3 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 3
NUMA node: 0
00: de 10 7f 02 00 01 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 7f 02
00:00.7 RAM memory: NVIDIA Corporation C51 Memory Controller 2 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 2
NUMA node: 0
00: de 10 7e 02 00 00 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 7e 02
00:02.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
NUMA node: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: fd800000-fd8fffff
Prefetchable memory behind bridge: 00000000fd700000-00000000fd7fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation C51 PCI Express Bridge
Capabilities: [48] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Capabilities: [80] Express (v1) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #2, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=WRR32
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Kernel driver in use: pcieport
00: de 10 fc 02 07 00 10 00 a1 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 00 01 01 00 a1 a1 00 00
20: 80 fd 80 fd 71 fd 71 fd 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 ff 00 04 00
00:03.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00007000-00007fff
Memory behind bridge: fde00000-fdefffff
Prefetchable memory behind bridge: 00000000fdd00000-00000000fddfffff
ExtTag- RBE-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
Status: InProgress-
00: de 10 fd 02 07 00 10 00 a1 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 00 02 02 00 71 71 00 00
20: e0 fd e0 fd d1 fd d1 fd 00 00 00 00 00 00 00 00
00:04.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: fdc00000-fdcfffff
Prefetchable memory behind bridge: 00000000fd900000-00000000fd9fffff
ExtTag- RBE-
LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Status: InProgress-
00: de 10 fb 02 07 00 10 00 a1 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 00 03 03 00 b1 b1 00 00
20: c0 fd c0 fd 91 fd 91 fd 00 00 00 00 00 00 00 00
00:05.0 VGA compatible controller: NVIDIA Corporation C51 [GeForce 6150 LE] (rev a2) (prog-if 00 [VGA controller])
Subsystem: Dell C51 [GeForce 6150 LE]
Latency: 0
Interrupt: pin A routed to IRQ 16
NUMA node: 0
Region 0: Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at fb000000 (64-bit, non-prefetchable) [size=16M]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: nouveau
Kernel modules: nouveau
00: de 10 41 02 07 00 b0 00 a2 00 00 03 00 00 00 00
10: 00 00 00 fc 0c 00 00 e0 00 00 00 00 04 00 00 fb
20: 00 00 00 00 00 00 00 00 00 00 00 00 28 10 ed 01
30: 00 00 00 00 48 00 00 00 00 00 00 00 07 01 00 00
00:09.0 RAM memory: NVIDIA Corporation MCP51 Host Bridge (rev a2)
Subsystem: NVIDIA Corporation MCP51 Host Bridge
Latency: 0
NUMA node: 0
Command: BaseUnitID=9 UnitCnt=15 MastHost- DefDir- DUL-
Link Control 0: CFlE+ CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn+ ExtCTL- 64b-
Link Config 0: MLWI=8bit DwFcIn- MLWO=8bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Link Control 1: CFlE- CST- CFE- <LkFail+ Init- EOC+ TXO+ <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config 1: MLWI=8bit DwFcIn- MLWO=8bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Revision ID: 1.03
Link Frequency 0: 800MHz
Link Frequency 1: 200MHz
Link Frequency Capability 1: 200MHz- 300MHz- 400MHz- 500MHz- 600MHz- 800MHz- 1.0GHz- 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Bus Number: 00
Capabilities: [e0] HyperTransport: MSI Mapping Enable- Fixed-
00: de 10 70 02 06 00 b0 00 a2 00 00 05 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 84 cb
00:0a.0 ISA bridge: NVIDIA Corporation MCP51 LPC Bridge (rev a3)
Subsystem: Dell MCP51 LPC Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
NUMA node: 0
00: de 10 60 02 0f 00 a0 00 a3 00 01 06 00 00 80 00
00:0a.1 SMBus: NVIDIA Corporation MCP51 SMBus (rev a3)
Subsystem: Dell MCP51 SMBus
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 7
NUMA node: 0
Region 4: I/O ports at 1c00
Region 5: I/O ports at 1c40
Capabilities: [44] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Kernel driver in use: nForce2_smbus
Kernel modules: i2c_nforce2, nv_tco
00: de 10 64 02 01 00 b0 00 a3 00 05 0c 00 00 80 00
20: 01 1c 00 00 41 1c 00 00 00 00 00 00 28 10 ed 01
30: 00 00 00 00 44 00 00 00 00 00 00 00 07 01 00 00
00:0a.2 RAM memory: NVIDIA Corporation MCP51 Memory Controller 0 (rev a3)
Subsystem: Dell MCP51 Memory Controller 0
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
NUMA node: 0
00: de 10 72 02 00 04 a0 00 a3 00 00 05 00 00 80 00
00:0b.0 USB controller: NVIDIA Corporation MCP51 USB Controller (rev a3) (prog-if 10 [OHCI])
Subsystem: Dell MCP51 USB Controller
Latency: 0 (750ns min, 250ns max)
Interrupt: pin A routed to IRQ 23
NUMA node: 0
Region 0: Memory at fe02f000 (32-bit, non-prefetchable) [size=4K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Kernel driver in use: ohci-pci
Kernel modules: ohci_pci
00: de 10 6d 02 07 00 b0 00 a3 10 03 0c 00 00 80 00
10: 00 f0 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 44 00 00 00 00 00 00 00 0f 01 03 01
00:0b.1 USB controller: NVIDIA Corporation MCP51 USB Controller (rev a3) (prog-if 20 [EHCI])
Interrupt: pin B routed to IRQ 22
NUMA node: 0
Region 0: Memory at fe02e000 (32-bit, non-prefetchable)
Capabilities: [44] Debug port: BAR=1 offset=0098
Capabilities: [80] Power Management version 2
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00: de 10 6e 02 06 00 b0 00 a3 20 03 0c 00 00 80 00
10: 00 e0 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 44 00 00 00 00 00 00 00 05 02 03 01
00:0e.0 IDE interface: NVIDIA Corporation MCP51 Serial ATA Controller (rev a1) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Subsystem: Dell MCP51 Serial ATA Controller
Interrupt: pin A routed to IRQ 21
NUMA node: 0
Region 0: I/O ports at 09f0
Region 1: I/O ports at 0bf0
Region 2: I/O ports at 0970
Region 3: I/O ports at 0b70
Region 4: I/O ports at e000
Region 5: Memory at fe02d000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [b0] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [cc] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: sata_nv
Kernel modules: sata_nv, ata_generic
00: de 10 66 02 07 00 b0 00 a1 85 01 01 00 00 00 00
10: f1 09 00 00 f1 0b 00 00 71 09 00 00 71 0b 00 00
20: 01 e0 00 00 00 d0 02 fe 00 00 00 00 28 10 ed 01
30: 00 00 00 00 44 00 00 00 00 00 00 00 0b 01 03 01
00:0f.0 IDE interface: NVIDIA Corporation MCP51 Serial ATA Controller (rev a1) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Interrupt: pin A routed to IRQ 20
NUMA node: 0
Region 0: I/O ports at 09e0
Region 1: I/O ports at 0be0
Region 2: I/O ports at 0960
Region 3: I/O ports at 0b60
Region 4: I/O ports at cc00
Region 5: Memory at fe02c000 (32-bit, non-prefetchable) [size=4K]
00: de 10 67 02 07 00 b0 00 a1 85 01 01 00 00 00 00
10: e1 09 00 00 e1 0b 00 00 61 09 00 00 61 0b 00 00
20: 01 cc 00 00 00 c0 02 fe 00 00 00 00 28 10 ed 01
30: 00 00 00 00 44 00 00 00 00 00 00 00 0a 01 03 01
00:10.0 PCI bridge: NVIDIA Corporation MCP51 PCI Bridge (rev a2) (prog-if 01 [Subtractive decode])
Latency: 0
NUMA node: 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
I/O behind bridge: 00008000-00009fff
Memory behind bridge: fdb00000-fdbfffff
Prefetchable memory behind bridge: fda00000-fdafffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
PriDiscTmr- SecDiscTmr+ DiscTmrStat- DiscTmrSERREn-
Capabilities: [b8] Subsystem: Device 0000:0000
Capabilities: [8c] HyperTransport: MSI Mapping Enable+ Fixed-
00: de 10 6f 02 07 00 b0 00 a2 01 04 06 00 00 81 00
10: 00 00 00 00 00 00 00 00 00 04 04 20 80 90 80 02
20: b0 fd b0 fd a0 fd a0 fd 00 00 00 00 00 00 00 00
30: 00 00 00 00 b8 00 00 00 00 00 00 00 ff 00 04 02
00:10.1 Audio device: NVIDIA Corporation MCP51 High Definition Audio (rev a2)
Subsystem: Dell MCP51 High Definition Audio
Latency: 0 (500ns min, 1250ns max)
Interrupt: pin B routed to IRQ 23
NUMA node: 0
Region 0: Memory at fe024000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [6c] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00: de 10 6c 02 06 00 b0 00 a2 00 03 04 00 00 80 00
10: 00 40 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 44 00 00 00 00 00 00 00 0b 02 02 05
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
NUMA node: 0
Capabilities: [80] HyperTransport: Host or Secondary Interface
Command: WarmRst+ DblEnd- DevNum=0 ChainSide- HostHide+ Slave- <EOCErr- DUL-
Link Control: CFlE- CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=16bit DwFcInEn- LWO=16bit DwFcOutEn-
Revision ID: 1.02
Link Frequency: 1.0GHz
Link Error: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability: 200MHz+ 300MHz- 400MHz+ 500MHz- 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Feature Capability: IsocFC- LDTSTOP+ CRCTM- ECTLT- 64bA- UIDRD- ExtRS- UCnfE-
00: 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00: 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
NUMA node: 0
00: 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
NUMA node: 0
Capabilities: [f0] Secure device <?>
Kernel driver in use: k8temp
Kernel modules: k8temp
00: 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30: 00 00 00 00 f0 00 00 00 00 00 00 00 00 00 00 00
04:07.0 Ethernet controller: Broadcom Limited BCM4401-B0 100Base-TX (rev 02)
Subsystem: Dell BCM4401-B0 100Base-TX
Latency: 64
Interrupt: pin A routed to IRQ 19
NUMA node: 0
Region 0: Memory at fdbfe000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [40] Power Management version 2
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=2 PME-
Kernel driver in use: b44
Kernel modules: b44
00: e4 14 0c 17 06 00 10 00 02 00 00 02 00 40 00 00
10: 00 e0 bf fd 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 05 01 00 00
04:08.0 Communication controller: Conexant Systems, Inc. SoftV92 SpeakerPhone SoftRing Modem with SmartSP (rev 01)
Subsystem: Conexant Systems, Inc. SoftV92 SpeakerPhone SoftRing Modem with SmartSP
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
Region 0: Memory at fdbe0000 (32-bit, non-prefetchable) [size=64K]
Region 1: I/O ports at 9c00
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
00: f1 14 30 2f 07 00 90 02 01 00 80 07 00 00 00 00
10: 00 00 be fd 01 9c 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 f1 14 00 20
30: 00 00 00 00 40 00 00 00 00 00 00 00 07 01 00 00
04:09.0 Communication controller: MosChip Semiconductor Technology Ltd. PCI 9815 Multi-I/O Controller (rev 01)
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin A routed to IRQ 17
NUMA node: 0
Region 0: I/O ports at 9800
Region 1: I/O ports at 9400
Region 2: I/O ports at 9000
Region 3: I/O ports at 8c00
Region 4: I/O ports at 8800
Region 5: I/O ports at 8400
00: 10 97 15 98 01 00 80 02 01 00 80 07 10 00 00 00
10: 01 98 00 00 01 94 00 00 01 90 00 00 01 8c 00 00
20: 01 88 00 00 01 84 00 00 00 00 00 00 00 10 20 00
30: 00 00 00 00 00 00 00 00 00 00 00 00 05 01 00 00
laurence@Router1:~$
Latency: 0
NUMA node: 0
Revision ID: 1.03
Bus Number: 00
NUMA node: 0
NUMA node: 0
NUMA node: 0
Latency: 0
NUMA node: 0
Latency: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
ExtTag- RBE-
Status: InProgress-
NUMA node: 0
ExtTag- RBE-
Status: InProgress-
NUMA node: 0
ExtTag- RBE-
Status: InProgress-
Latency: 0
NUMA node: 0
Latency: 0
NUMA node: 0
Revision ID: 1.03
Bus Number: 00
Latency: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
Latency: 0
NUMA node: 0
NUMA node: 0
NUMA node: 0
Revision ID: 1.02
NUMA node: 0
NUMA node: 0
NUMA node: 0
Latency: 64
NUMA node: 0
Kernel modules: b44
Latency: 0
NUMA node: 0
NUMA node: 0
laurence@Router1:~$
25 Aug 2022 19:12 #250479
Now we are getting somewhere, those are the addresses that need to be entered in StepConf when setting it up, since you are using only the first header try only the first 3, so first try
0x9800
and so on, but do add 0x in front, and it would be good to restart the PC before testing a new address.
0x9800
- Routerworks
25 Aug 2022 19:18 #250481
by Routerworks
Great, I'll give it a try.
- Routerworks
26 Aug 2022 10:11 #250521
by Routerworks
It looks like there is only room to enter one address for the board. I read that when 0 is entered it will look for the first available. Entering )x0378 will look for that address only. Not sure how to enter 0x9800 etc.
Am I confusing the board address with addresses for each axis?
- LinuxCNC
Time to create page: 0.152 seconds
