Attached parallel board to breakout board can't open up linuxcnc anymore
23 Aug 2022 10:40 #250264 by Routerworks
I had bought and installed a parallel board (no drivers) and was able to set up and use linuxcnc wizard no problems.  I then attached the parallel port to a breakout board (new) and it all went south.I am attaching the report.No idea what to do.Thanks for any help
23 Aug 2022 10:42 #250265 by Routerworks
23 Aug 2022 10:48 #250266 by Routerworks
File Name: linuxcncreport.txt
File Size:7 KB
23 Aug 2022 15:56 #250283 by JT
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hal_parport.ko: No such device
Looks like the parallel port is not found.
JT
23 Aug 2022 16:13 #250284 by probamo
I had issue as well, kernel less then 4 does not recognize attached boards. Install kernel 4.xx and higher then you'll get recognize you parport card.
23 Aug 2022 17:05 - 23 Aug 2022 17:08 #250288 by Bari
What do you mean by installed? Pushed into the PCI/e slot or?
Were you able to test the card using Stepconf with the BOB attached to a stepper motor and driver?
Last edit: 23 Aug 2022 17:08 by Bari. Reason: spelling
23 Aug 2022 18:11 #250290 by Routerworks
I should have been more clear. By "install" I meant I pushed the pci (not pci/e) into the slot.
Not familiar with "stepconfig" Is that a terminal command? I can hook up the rest.
Where do I find the kernel greater than 4.xxx?
Maybe I should reinstall the whole system if there is a version that will cover all of this.
Thanks all for your help.
23 Aug 2022 18:21 #250291 by Bari
I see you are still running Debian Wheezy with LCNC 2.8.3.
There might be newer kernel backports for Wheezy but you can just upgrade to Buster
www.linuxcnc.org/downloads/ with all 5.x kernels
23 Aug 2022 18:53 #250293 by Routerworks
Sounds reasonable to me. Im not sure what giving up some realtime performance equates to but I plan not to have anything else running while operating the router.
23 Aug 2022 19:00 - 23 Aug 2022 19:03 #250296 by Bari
Just run a preempt_rt kernel and you'll likely be fine.
What are you referring to here? Why do you think that by upgrading to Buster and 5.x kernels would have an effect on realtime?
Last edit: 23 Aug 2022 19:03 by Bari.
Time to create page: 0.136 seconds
