laurence@Router1:~$ cat /proc/ioports | grep parport
laurence@Router1:~$ sudo lspci -v | grep par
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for laurence:
Kernel modules: parport_pc
laurence@Router1:~$
laurence@Router1:~$ sudo lspci -vvxx
00:00.0 RAM memory: NVIDIA Corporation C51 Host Bridge (rev a2)
Subsystem: NVIDIA Corporation C51 Host Bridge
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
Capabilities: [44] HyperTransport: Slave or Primary Interface
Command: BaseUnitID=0 UnitCnt=15 MastHost- DefDir- DUL-
Link Control 0: CFlE+ CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config 0: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=16bit DwFcInEn- LWO=16bit DwFcOutEn-
Link Control 1: CFlE+ CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn+ ExtCTL- 64b-
Link Config 1: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Revision ID: 1.03
Link Frequency 0: 1.0GHz
Link Error 0: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability 0: 200MHz+ 300MHz+ 400MHz+ 500MHz+ 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Feature Capability: IsocFC+ LDTSTOP+ CRCTM- ECTLT- 64bA- UIDRD-
Link Frequency 1: 800MHz
Link Error 1: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability 1: 200MHz+ 300MHz+ 400MHz+ 500MHz+ 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Error Handling: PFlE+ OFlE+ PFE- OFE- EOCFE- RFE- CRCFE- SERRFE- CF- RE- PNFE- ONFE- EOCNFE- RNFE- CRCNFE- SERRNFE-
Prefetchable memory behind bridge Upper: 00-00
Bus Number: 00
Capabilities: [e0] HyperTransport: MSI Mapping Enable+ Fixed-
Mapping Address Base: 00000000fee00000
00: de 10 f0 02 06 00 b0 00 a2 00 00 05 00 00 80 00
10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 f0 02
30: 00 00 00 00 44 00 00 00 00 00 00 00 ff 00 00 00
00:00.1 RAM memory: NVIDIA Corporation C51 Memory Controller 0 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 0
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00: de 10 fa 02 00 01 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 fa 02
30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00:00.2 RAM memory: NVIDIA Corporation C51 Memory Controller 1 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 1
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
NUMA node: 0
00: de 10 fe 02 00 00 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 fe 02
00:00.3 RAM memory: NVIDIA Corporation C51 Memory Controller 5 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 5
Status: Cap- 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00: de 10 f8 02 00 00 a0 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 f8 02
30: 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00
00:00.4 RAM memory: NVIDIA Corporation C51 Memory Controller 4 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 4
Latency: 0
NUMA node: 0
00: de 10 f9 02 06 00 a0 00 a2 00 00 05 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 f9 02
00:00.5 RAM memory: NVIDIA Corporation C51 Host Bridge (rev a2)
Latency: 0
NUMA node: 0
Capabilities: [44] #00 [00fe]
Capabilities: [fc] #00 [0000]
00: de 10 ff 02 06 00 b0 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 ff 02
00:00.6 RAM memory: NVIDIA Corporation C51 Memory Controller 3 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 3
NUMA node: 0
00: de 10 7f 02 00 01 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 7f 02
00:00.7 RAM memory: NVIDIA Corporation C51 Memory Controller 2 (rev a2)
Subsystem: NVIDIA Corporation C51 Memory Controller 2
NUMA node: 0
00: de 10 7e 02 00 00 20 00 a2 00 00 05 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 7e 02
00:02.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
NUMA node: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: 0000a000-0000afff
Memory behind bridge: fd800000-fd8fffff
Prefetchable memory behind bridge: 00000000fd700000-00000000fd7fffff
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Subsystem: NVIDIA Corporation C51 PCI Express Bridge
Capabilities: [48] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Address: 0000000000000000 Data: 0000
Capabilities: [60] HyperTransport: MSI Mapping Enable- Fixed-
Capabilities: [80] Express (v1) Root Port (Slot+), MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0
ExtTag- RBE-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #2, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
ClockPM- Surprise- LLActRep+ BwNot- ASPMOptComp-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd On, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet- Interlock-
Changed: MRL- PresDet- LinkState-
RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna- CRSVisible-
RootCap: CRSVisible-
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=WRR32
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=ff
Status: NegoPending- InProgress-
Kernel driver in use: pcieport
00: de 10 fc 02 07 00 10 00 a1 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 00 01 01 00 a1 a1 00 00
20: 80 fd 80 fd 71 fd 71 fd 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 ff 00 04 00
00:03.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
I/O behind bridge: 00007000-00007fff
Memory behind bridge: fde00000-fdefffff
Prefetchable memory behind bridge: 00000000fdd00000-00000000fddfffff
ExtTag- RBE-
LnkCap: Port #1, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
Status: InProgress-
00: de 10 fd 02 07 00 10 00 a1 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 00 02 02 00 71 71 00 00
20: e0 fd e0 fd d1 fd d1 fd 00 00 00 00 00 00 00 00
00:04.0 PCI bridge: NVIDIA Corporation C51 PCI Express Bridge (rev a1) (prog-if 00 [Normal decode])
NUMA node: 0
Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
I/O behind bridge: 0000b000-0000bfff
Memory behind bridge: fdc00000-fdcfffff
Prefetchable memory behind bridge: 00000000fd900000-00000000fd9fffff
ExtTag- RBE-
LnkCap: Port #0, Speed 2.5GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <512ns, L1 <4us
LnkSta: Speed 2.5GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
Status: InProgress-
00: de 10 fb 02 07 00 10 00 a1 00 04 06 10 00 01 00
10: 00 00 00 00 00 00 00 00 00 03 03 00 b1 b1 00 00
20: c0 fd c0 fd 91 fd 91 fd 00 00 00 00 00 00 00 00
00:05.0 VGA compatible controller: NVIDIA Corporation C51 [GeForce 6150 LE] (rev a2) (prog-if 00 [VGA controller])
Subsystem: Dell C51 [GeForce 6150 LE]
Latency: 0
Interrupt: pin A routed to IRQ 16
NUMA node: 0
Region 0: Memory at fc000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at e0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at fb000000 (64-bit, non-prefetchable) [size=16M]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel driver in use: nouveau
Kernel modules: nouveau
00: de 10 41 02 07 00 b0 00 a2 00 00 03 00 00 00 00
10: 00 00 00 fc 0c 00 00 e0 00 00 00 00 04 00 00 fb
20: 00 00 00 00 00 00 00 00 00 00 00 00 28 10 ed 01
30: 00 00 00 00 48 00 00 00 00 00 00 00 07 01 00 00
00:09.0 RAM memory: NVIDIA Corporation MCP51 Host Bridge (rev a2)
Subsystem: NVIDIA Corporation MCP51 Host Bridge
Latency: 0
NUMA node: 0
Command: BaseUnitID=9 UnitCnt=15 MastHost- DefDir- DUL-
Link Control 0: CFlE+ CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn+ ExtCTL- 64b-
Link Config 0: MLWI=8bit DwFcIn- MLWO=8bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Link Control 1: CFlE- CST- CFE- <LkFail+ Init- EOC+ TXO+ <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config 1: MLWI=8bit DwFcIn- MLWO=8bit DwFcOut- LWI=8bit DwFcInEn- LWO=8bit DwFcOutEn-
Revision ID: 1.03
Link Frequency 0: 800MHz
Link Frequency 1: 200MHz
Link Frequency Capability 1: 200MHz- 300MHz- 400MHz- 500MHz- 600MHz- 800MHz- 1.0GHz- 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Bus Number: 00
Capabilities: [e0] HyperTransport: MSI Mapping Enable- Fixed-
00: de 10 70 02 06 00 b0 00 a2 00 00 05 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 de 10 84 cb
00:0a.0 ISA bridge: NVIDIA Corporation MCP51 LPC Bridge (rev a3)
Subsystem: Dell MCP51 LPC Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
NUMA node: 0
00: de 10 60 02 0f 00 a0 00 a3 00 01 06 00 00 80 00
00:0a.1 SMBus: NVIDIA Corporation MCP51 SMBus (rev a3)
Subsystem: Dell MCP51 SMBus
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 7
NUMA node: 0
Region 4: I/O ports at 1c00
Region 5: I/O ports at 1c40
Capabilities: [44] Power Management version 2
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
Kernel driver in use: nForce2_smbus
Kernel modules: i2c_nforce2, nv_tco
00: de 10 64 02 01 00 b0 00 a3 00 05 0c 00 00 80 00
20: 01 1c 00 00 41 1c 00 00 00 00 00 00 28 10 ed 01
30: 00 00 00 00 44 00 00 00 00 00 00 00 07 01 00 00
00:0a.2 RAM memory: NVIDIA Corporation MCP51 Memory Controller 0 (rev a3)
Subsystem: Dell MCP51 Memory Controller 0
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
NUMA node: 0
00: de 10 72 02 00 04 a0 00 a3 00 00 05 00 00 80 00
00:0b.0 USB controller: NVIDIA Corporation MCP51 USB Controller (rev a3) (prog-if 10 [OHCI])
Subsystem: Dell MCP51 USB Controller
Latency: 0 (750ns min, 250ns max)
Interrupt: pin A routed to IRQ 23
NUMA node: 0
Region 0: Memory at fe02f000 (32-bit, non-prefetchable) [size=4K]
Flags: PMEClk- DSI- D1+ D2+ AuxCurrent=0mA PME(D0+,D1+,D2+,D3hot+,D3cold+)
Kernel driver in use: ohci-pci
Kernel modules: ohci_pci
00: de 10 6d 02 07 00 b0 00 a3 10 03 0c 00 00 80 00
10: 00 f0 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 44 00 00 00 00 00 00 00 0f 01 03 01
00:0b.1 USB controller: NVIDIA Corporation MCP51 USB Controller (rev a3) (prog-if 20 [EHCI])
Interrupt: pin B routed to IRQ 22
NUMA node: 0
Region 0: Memory at fe02e000 (32-bit, non-prefetchable)
Capabilities: [44] Debug port: BAR=1 offset=0098
Capabilities: [80] Power Management version 2
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00: de 10 6e 02 06 00 b0 00 a3 20 03 0c 00 00 80 00
10: 00 e0 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 44 00 00 00 00 00 00 00 05 02 03 01
00:0e.0 IDE interface: NVIDIA Corporation MCP51 Serial ATA Controller (rev a1) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Subsystem: Dell MCP51 Serial ATA Controller
Interrupt: pin A routed to IRQ 21
NUMA node: 0
Region 0: I/O ports at 09f0
Region 1: I/O ports at 0bf0
Region 2: I/O ports at 0970
Region 3: I/O ports at 0b70
Region 4: I/O ports at e000
Region 5: Memory at fe02d000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [b0] MSI: Enable- Count=1/4 Maskable- 64bit+
Capabilities: [cc] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: sata_nv
Kernel modules: sata_nv, ata_generic
00: de 10 66 02 07 00 b0 00 a1 85 01 01 00 00 00 00
10: f1 09 00 00 f1 0b 00 00 71 09 00 00 71 0b 00 00
20: 01 e0 00 00 00 d0 02 fe 00 00 00 00 28 10 ed 01
30: 00 00 00 00 44 00 00 00 00 00 00 00 0b 01 03 01
00:0f.0 IDE interface: NVIDIA Corporation MCP51 Serial ATA Controller (rev a1) (prog-if 85 [PCI native mode-only controller, supports bus mastering])
Interrupt: pin A routed to IRQ 20
NUMA node: 0
Region 0: I/O ports at 09e0
Region 1: I/O ports at 0be0
Region 2: I/O ports at 0960
Region 3: I/O ports at 0b60
Region 4: I/O ports at cc00
Region 5: Memory at fe02c000 (32-bit, non-prefetchable) [size=4K]
00: de 10 67 02 07 00 b0 00 a1 85 01 01 00 00 00 00
10: e1 09 00 00 e1 0b 00 00 61 09 00 00 61 0b 00 00
20: 01 cc 00 00 00 c0 02 fe 00 00 00 00 28 10 ed 01
30: 00 00 00 00 44 00 00 00 00 00 00 00 0a 01 03 01
00:10.0 PCI bridge: NVIDIA Corporation MCP51 PCI Bridge (rev a2) (prog-if 01 [Subtractive decode])
Latency: 0
NUMA node: 0
Bus: primary=00, secondary=04, subordinate=04, sec-latency=32
I/O behind bridge: 00008000-00009fff
Memory behind bridge: fdb00000-fdbfffff
Prefetchable memory behind bridge: fda00000-fdafffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR+
PriDiscTmr- SecDiscTmr+ DiscTmrStat- DiscTmrSERREn-
Capabilities: [b8] Subsystem: Device 0000:0000
Capabilities: [8c] HyperTransport: MSI Mapping Enable+ Fixed-
00: de 10 6f 02 07 00 b0 00 a2 01 04 06 00 00 81 00
10: 00 00 00 00 00 00 00 00 00 04 04 20 80 90 80 82
20: b0 fd b0 fd a0 fd a0 fd 00 00 00 00 00 00 00 00
30: 00 00 00 00 b8 00 00 00 00 00 00 00 ff 00 04 02
00:10.1 Audio device: NVIDIA Corporation MCP51 High Definition Audio (rev a2)
Subsystem: Dell MCP51 High Definition Audio
Latency: 0 (500ns min, 1250ns max)
Interrupt: pin B routed to IRQ 23
NUMA node: 0
Region 0: Memory at fe024000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Masking: 00000000 Pending: 00000000
Capabilities: [6c] HyperTransport: MSI Mapping Enable+ Fixed+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00: de 10 6c 02 06 00 b0 00 a2 00 03 04 00 00 80 00
10: 00 40 02 fe 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 44 00 00 00 00 00 00 00 0b 02 02 05
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
NUMA node: 0
Capabilities: [80] HyperTransport: Host or Secondary Interface
Command: WarmRst+ DblEnd- DevNum=0 ChainSide- HostHide+ Slave- <EOCErr- DUL-
Link Control: CFlE- CST- CFE- <LkFail- Init+ EOC- TXO- <CRCErr=0 IsocEn- LSEn- ExtCTL- 64b-
Link Config: MLWI=16bit DwFcIn- MLWO=16bit DwFcOut- LWI=16bit DwFcInEn- LWO=16bit DwFcOutEn-
Revision ID: 1.02
Link Frequency: 1.0GHz
Link Error: <Prot- <Ovfl- <EOC- CTLTm-
Link Frequency Capability: 200MHz+ 300MHz- 400MHz+ 500MHz- 600MHz+ 800MHz+ 1.0GHz+ 1.2GHz- 1.4GHz- 1.6GHz- Vend-
Feature Capability: IsocFC- LDTSTOP+ CRCTM- ECTLT- 64bA- UIDRD- ExtRS- UCnfE-
00: 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
NUMA node: 0
00: 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
NUMA node: 0
00: 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
NUMA node: 0
Capabilities: [f0] Secure device <?>
Kernel driver in use: k8temp
Kernel modules: k8temp
00: 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30: 00 00 00 00 f0 00 00 00 00 00 00 00 00 00 00 00
04:07.0 Ethernet controller: Broadcom Limited BCM4401-B0 100Base-TX (rev 02)
Subsystem: Dell BCM4401-B0 100Base-TX
Latency: 64
Interrupt: pin A routed to IRQ 19
NUMA node: 0
Region 0: Memory at fdbfe000 (32-bit, non-prefetchable) [size=8K]
Capabilities: [40] Power Management version 2
Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=2 PME-
Kernel driver in use: b44
Kernel modules: b44
00: e4 14 0c 17 06 00 10 00 02 00 00 02 00 40 00 00
10: 00 e0 bf fd 00 00 00 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 05 01 00 00
04:08.0 Communication controller: Conexant Systems, Inc. SoftV92 SpeakerPhone SoftRing Modem with SmartSP (rev 01)
Subsystem: Conexant Systems, Inc. SoftV92 SpeakerPhone SoftRing Modem with SmartSP
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
NUMA node: 0
Region 0: Memory at fdbe0000 (32-bit, non-prefetchable) [size=64K]
Region 1: I/O ports at 9c00
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot+,D3cold+)
00: f1 14 30 2f 07 00 90 02 01 00 80 07 00 00 00 00
10: 00 00 be fd 01 9c 00 00 00 00 00 00 00 00 00 00
20: 00 00 00 00 00 00 00 00 00 00 00 00 f1 14 00 20
30: 00 00 00 00 40 00 00 00 00 00 00 00 07 01 00 00
04:09.0 Communication controller: MosChip Semiconductor Technology Ltd. PCI 9815 Multi-I/O Controller (rev ff) (prog-if ff)
!!! Unknown header type 7f
00: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
laurence@Router1:~$
