Attached parallel board to breakout board can't open up linuxcnc anymore
4 years 2 months ago #250290 by Routerworks
I should have been more clear. By "install" I meant I pushed the pci (not pci/e) into the slot.
Not familiar with "stepconfig" Is that a terminal command? I can hook up the rest.
Where do I find the kernel greater than 4.xxx?
Maybe I should reinstall the whole system if there is a version that will cover all of this.
Thanks all for your help.
4 years 2 months ago #250291 by Bari
I see you are still running Debian Wheezy with LCNC 2.8.3.
There might be newer kernel backports for Wheezy but you can just upgrade to Buster
www.linuxcnc.org/downloads/ with all 5.x kernels
4 years 2 months ago #250293 by Routerworks
Sounds reasonable to me. Im not sure what giving up some realtime performance equates to but I plan not to have anything else running while operating the router.
4 years 2 months ago - 4 years 2 months ago #250296 by Bari
Just run a preempt_rt kernel and you'll likely be fine.
What are you referring to here? Why do you think that by upgrading to Buster and 5.x kernels would have an effect on realtime?
Last edit: 4 years 2 months ago by Bari.
4 years 2 months ago #250300 by Routerworks
A number of web sites state the older version of lcnc wheezy is still the more stable realtime version. They recommend those new to this should start there.
Who knew.
Plan to install lcnc Buster 5.x.
Let you know how it works out.
4 years 2 months ago #250323 by Routerworks
Time to create page: 0.378 seconds
