5i22- how do I add a 7i44 to my config?
- M4MazakUser
- Thank you received: 7
26 Sep 2022 22:45 #252812
by M4MazakUser
5i22- how do I add a 7i44 to my config? was created by M4MazakUser
I have a 5i22, and several other cards, for starters, how do I add the 7i44 to the standard config and get attached cards working. I'm not after step by step, just pointers.
I have the card working on the 5i22 demo program, though the bit file had to be placed for it to work. And pncconf dosent seem to like the 5i22.
- Thank you received: 5308
27 Sep 2022 00:01 #252814
Replied by PCW on topic 5i22- how do I add a 7i44 to my config?
First you would need firmware that supports the 7I44 and
whatever other daughter cards that are connected to the 5I22's
50 pin connectors
50 pin connectors
- M4MazakUser
27 Sep 2022 00:49 #252817
by M4MazakUser
Replied by M4MazakUser on topic 5i22- how do I add a 7i44 to my config?
Does this exist?
27 Sep 2022 02:12 #252820
It can be made, given the required daughterboards and desired features
The following user(s) said Thank You: M4MazakUser
- M4MazakUser
27 Sep 2022 02:21 #252821
by M4MazakUser
Ok, cool, what compiler etc do I use? Any links
27 Sep 2022 02:27 #252823
You would use Xilinx Webpack 14.7, but I can make a
bitfile if you indicate what daughterboards you need supported
- M4MazakUser
27 Sep 2022 02:51 #252826
by M4MazakUser
Due to stock issues, I have the following
2x 8i20 cards
1x 7i73
1x 7i72
1x 7i84d
1x 7i44
A 7i37ta
And a 7i47 for fanuc encoder connection
Oh, and a 5i22 1.5
If you can build a firmware that would be great thanks.
2x 8i20 cards
1x 7i73
1x 7i72
1x 7i84d
1x 7i44
A 7i37ta
Oh, and a 5i22 1.5
- M4MazakUser
27 Sep 2022 08:29 #252837
by M4MazakUser
Damn, i tried the fanuc power supply that came with the machine and its putting out 320vdc, not 220v, so I'll have to build a power supply.
27 Sep 2022 16:26 - 27 Sep 2022 16:29 #252864
So basically you need a configuration for
1 7I47
1 7I44
1 7I37TA
Note: 320VDC is OK for a 8I20
What type of encoders are on the Fanuc motors?
1 7I47
1 7I44
1 7I37TA
Last edit: 27 Sep 2022 16:29 by PCW.
- M4MazakUser
27 Sep 2022 19:23 #252884
by M4MazakUser
There's a 10pin plug, I'm assuming a-b-z, but fanuc style, the absolute seem to have more pins.
The cap says pulsecoder
aiA1000
Type A860-2000-T301
aiA1000
Type A860-2000-T301
