5i22- how do I add a 7i44 to my config?
- Thank you received: 5308
27 Sep 2022 19:36 #252888
Replied by PCW on topic 5i22- how do I add a 7i44 to my config?
I think that's a 1,000,000 count per turn serial encoder
- M4MazakUser
- Thank you received: 7
27 Sep 2022 22:11 #252893
by M4MazakUser
Replied by M4MazakUser on topic 5i22- how do I add a 7i44 to my config?
Its hard to find real info on them
- M4MazakUser
28 Sep 2022 01:08 #252904
by M4MazakUser
Ok, so it's definitely a serial encoder, though it looks like many people have used them before with linuxcnc. I found a "fanuc servo amplifier ai series manual and the pins are only named
5v, 0v, 6v, fg, and RD and *RD the last two i geuss being serial.
- Thank you received: 1471
28 Sep 2022 14:11 #252940
Replied by Todd Zuercher on topic 5i22- how do I add a 7i44 to my config?
I have a dead one of those (same part # A860-2000-T301) on my desk in front of me, but I know next to nothing about it other than it is definitely absolute, probably serial and non functional.
- M4MazakUser
29 Sep 2022 19:21 #253045
by M4MazakUser
So the fanuc encoders are rs422 from what I've read in previous posts, not sure if there's a Way to use these with a 5i22, so would it be best to replace them with standard a-b-z encoders, i really want to get into wiring this thing and getting some movement out of it!
29 Sep 2022 20:48 #253048
If they are standard Fanuc type I serial encoders, there is firmware to read them.
- M4MazakUser
29 Sep 2022 21:41 #253055
by M4MazakUser
So if I ask really nicely? Any chance I could get a bit file for...
A 5i22
To run
A 7i44
Connected to 2x 8i20's
And a 7i72 and a 7i84d and a 7i73 pendant interface.
With a 7i37ta (i/o)
And a 7i47 that will do rs422 comms with the 2 servo encoders
The spindle drive will be easy enough to configure later on. It's ordered and is a simple on/reverse/ 0-5(or10v) .
A 5i22
To run
A 7i44
With a 7i37ta (i/o)
- M4MazakUser
30 Sep 2022 01:13 #253073
by M4MazakUser
Actually after reading more... I see the encoders can connect directly to the 7i44.. haven't read a lot on this yet.
(Plenty of light reading to do...)
- Thank you received: 7462
30 Sep 2022 09:07 #253080
Needed new firmware though, PCW took care of that.
Thank you, PCW.
Replied by tommylight on topic 5i22- how do I add a 7i44 to my config?
Yes, some can, i have some serial absolute encoders in use for several years, wired to a 7i74, the 25 pin version if 7i44...i think.Actually after reading more... I see the encoders can connect directly to the 7i44.. haven't read a lot on this yet.
Thank you, PCW.
- M4MazakUser
30 Sep 2022 13:50 #253100
by M4MazakUser
I've found a 2017 firmware on github,
i22_1500 SV16 SVST8_24 SVST8_8 SVST2_4_7I47
The end one, does this (7i47) work the same as a 7i44 ??
Time to create page: 0.096 seconds
