5i22- how do I add a 7i44 to my config?
26 Sep 2022 22:45 #252812 by M4MazakUser
5i22- how do I add a 7i44 to my config? was created by M4MazakUser
I have a 5i22, and several other cards, for starters, how do I add the 7i44 to the standard config and get attached cards working. I'm not after step by step,  just pointers.
I have the card working on the 5i22 demo program,  though the bit file had to be placed for it to work. And pncconf dosent seem to like the 5i22.
27 Sep 2022 00:01 #252814 by PCW
Replied by PCW on topic 5i22- how do I add a 7i44 to my config?
First you would need firmware that supports the 7I44 and
whatever other daughter cards that are connected to the 5I22's
50 pin connectors
27 Sep 2022 00:49 #252817 by M4MazakUser
Replied by M4MazakUser on topic 5i22- how do I add a 7i44 to my config?
Does this exist?
27 Sep 2022 02:12 #252820 by PCW
It can be made, given the required daughterboards and desired features
The following user(s) said Thank You: M4MazakUser
27 Sep 2022 02:21 #252821 by M4MazakUser
Ok, cool, what compiler etc do I use? Any links
27 Sep 2022 02:27 #252823 by PCW
You would use Xilinx Webpack 14.7, but I can make a
bitfile if you indicate what daughterboards you need supported
27 Sep 2022 02:51 #252826 by M4MazakUser
Due to stock issues, I have the following
2x 8i20 cards
1x 7i73
1x 7i72
1x 7i84d
1x 7i44
A 7i37ta
And a 7i47 for fanuc encoder connection
Oh, and a 5i22 1.5
If you can build a firmware that would be great thanks.
27 Sep 2022 08:29 #252837 by M4MazakUser
Damn, i tried the fanuc power supply that came with the machine and its putting out 320vdc, not 220v,  so I'll have to build a power supply.
27 Sep 2022 16:26 - 27 Sep 2022 16:29 #252864 by PCW
So basically you need a configuration for
1 7I47
1 7I44
1 7I37TA
Note: 320VDC is OK for a 8I20
What type of encoders are on the Fanuc motors?
Last edit: 27 Sep 2022 16:29 by PCW.
27 Sep 2022 19:23 #252884 by M4MazakUser
There's a 10pin plug, I'm assuming a-b-z, but fanuc style, the absolute seem to have more pins.
The cap says pulsecoder
aiA1000
Type A860-2000-T301
Time to create page: 0.101 seconds
