7i76e -> 7i74 -> (7i72 + 7i87)
  • finnstrom
  • finnstrom's Avatar Topic Author
  • New Member
  • New Member
10 Oct 2022 22:05 #253920 by finnstrom
7i76e -> 7i74 -> (7i72 + 7i87) was created by finnstrom
Hello
I'd like to use the 7i76e with 7i74 on expansion port 0, then the 7i72 and 7i87 boards connected with cat 6 to the 7i74 ports 0 and 1.
Can I use bitfile 7i76e_7i76x1_7i74x1D.bit for this and
sserial_port_0=0x sserial_port1=00xxxxxxx
I referenced these posts but am quite new at this yet:
7i76E & 7i74
Mesa 7i74 support with 7i76e?
7i76E - 7I74 - 7i73 firmware
Thanks!
Finn
  • Moderator
  • Moderator
10 Oct 2022 22:12 #253921 by tommylight
Replied by tommylight on topic 7i76e -> 7i74 -> (7i72 + 7i87)
That should work, just check on what header to connect the 7i74 as there are two IDC26 headers on the 7i76E.
The following user(s) said Thank You: finnstrom
Time to create page: 0.106 seconds
