How to setup probe on Mesa 7i96
09 May 2023 17:41 #271045 by imslo
Replied by imslo on topic How to setup probe on Mesa 7i96
I don't see a 12 pin. Inputs go from 000 to 010. Everything else is output.
09 May 2023 17:44 #271046 by imslo
I don't see a 12 pin. Inputs go from 000 to 010. (You might get this twice. I thought I had sent it but it didn't show up.)
09 May 2023 17:57 - 09 May 2023 18:14 #271047 by PCW
Replied by PCW on topic How to setup probe on Mesa 7i96
TB3 pin 12 is the common for inputs 0..10 (TB3 pins 1..11)
Last edit: 09 May 2023 18:14 by PCW.
09 May 2023 18:07 #271048 by imslo
I can"t find that pin in the PNCCONF Wizard TB3 page.
09 May 2023 18:17 #271049 by PCW
Its a physical pin that determines input operation.
Inputs will not work unless is is connected properly
09 May 2023 18:19 #271050 by imslo
OK I guess I will have to take the board down. I have been running this exact set up for a year. What do I put on the #12 pin?
09 May 2023 18:31 #271052 by PCW
TB3 pin 12 is the input common
If the input devices supply positive voltages to the 7I96 inputs
(PNP type sensors or limit switches with one pin connected to a positive voltage)
the 7I96 input common would be grounded.
If the input devices ground the signal to the 7I96 inputs (NPN type sensors
or limit switches win one pin connected to ground), the input common
would be connected to +5 to +24V
09 May 2023 18:33 #271053 by imslo
I see that pin on pinout. I really don't don't think I have ever used that pin before but maybe I'm wrong.
09 May 2023 18:45 #271054 by imslo
OK thank you. I will pull the board out and ground that pin.
09 May 2023 22:44 #271069 by imslo
I installed the ground and it did not make any difference. It seems to me that the ground would only come into play on a probe trip. On the Hal Watch or whatever its called the probe is shown but when you go to the page that shows the red and yellow nothing is shown. I don't know if i programed it right. What i did was on tb3 pin 1 I selected external control and then probe in.
Time to create page: 0.342 seconds
