How to setup probe on Mesa 7i96
09 May 2023 23:23 #271071 by PCW
Replied by PCW on topic How to setup probe on Mesa 7i96
The input common _must_ be connected or none of the 11 inputs will work properly.
If you ground input common (TB3 pin 12), then apply +5 through +36V
to input 10 (TB3 pin 11) it should:
1. Light the yellow LED next to TB3 pin 11
2. Set hm2_7i96.gpio.010.in true = yellow in halshow
(check with halshow or "Machine Show Hal configuration" in axis)
10 May 2023 00:42 #271077 by imslo
Replied by imslo on topic How to setup probe on Mesa 7i96
I think I have it wired that way now. All I know to do now is pull the board back out to be sure it is wired that way. I will probably change pins from #1.
11 May 2023 19:26 #271173 by imslo
PROBE IS WORKING!!! Moved positive wire to pin 10. Thanks for bailing me out again.
Time to create page: 0.564 seconds
