Database of configuration files: Milling machine, lathes plasma
02 Jul 2023 13:23 #274638 by tommylight
1-Linuxcnc version
2-GUI
3-machine type
4-extra machine stuff like ATC
5-extra panels used, VCP, Glade
6-hardware used, parallel, 5i25, 7i96
7-fully working config or not
8-additional info on config functionality
9-info what attached file contains what
What did i forget?
First post should mention that LinuxCNC comes with a lot of working configs and a lot more of sims.
Anyone good at making gifs on how to use those configs? Should have:
Start LinuxCNC from menu
Navigate through config picker
Choose Yes when it asks to copy the config to ~/linuxcnc/configs folder
Use file explorer to edit those files, rename or copy, start by right clicking on the ini file and choosing the application > linuxcnc
The following user(s) said Thank You: cakeslob, spumco
