QTPlasmaC with six axis
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Oct 2023 01:37 #282338 by mariusl
QTPlasmaC with six axis was created by mariusl
Is it possible to run QTPlasmaC with six axis? XYZ as linear and ABC as rotary. Each rotary axis is rotating around its parent linear axis?
If not, what kind of effort will it take to achieve this?
Regards
Marius
www.bluearccnc.com
05 Oct 2023 05:50 #282352 by phillc54
Replied by phillc54 on topic QTPlasmaC with six axis
From memory it is limited to five axes, I will check tomorrow.
The following user(s) said Thank You: mariusl
06 Oct 2023 01:14 #282421 by phillc54
Currently it is limited to five axes.
If you want I could make a test branch in the next day or so that you could build and try out.
  • mariusl
  • Platinum Member
  • Platinum Member
06 Oct 2023 08:47 #282438 by mariusl
Replied by mariusl on topic QTPlasmaC with six axis
Thanks Phill. That would be great. I will work on the kinematics and the post processor for fusion. If we can make it work we will have an very awesome product for plasma cutting. Bevel cutting of parts and holes as well as tubes.
Regards
Marius
www.bluearccnc.com
06 Oct 2023 17:35 #282474 by rodw
Replied by rodw on topic QTPlasmaC with six axis
Marius, I had this idea a few days ago for bevel cutting.
I have an abandoned project that reports among other things the arc radius and the tangential heading in real time
github.com/LinuxCNC/linuxcnc/pull/900
Once 2.9 is released I had hoped to find the time to revisit it.
Assuming the following  5 axis design below, The A axis will determine the bevel angle
There will be a XY plane at the pivot point that is a constant Z height regardless of the direction of the bevel.
The distance from the torch tip to the pivot point in X & Y then can easilly be calculated from the A axis Angle
So given we have a tangential heading, we know the direction of the pivot point will be normal to the heading.
So now we just need a component that calculates the required X,Y position for a bevel cut in real time.
This component could then use external offsets to position the torch in the X,Y plane. Phils is the expert there :)
So this methodology would allow bevel cutting to be applied to a standard 2D DXF file cut without the need for any 5 axis kinematics.
Let me know your thoughts.
06 Oct 2023 18:40 #282479 by phillc54
I have pushed a new branch named phillc54/qtplasmac_6_axes which is based on master branch.
github.com/LinuxCNC/linuxcnc/tree/phillc54/qtplasmac_6_axes
The GUI's need a little bit of polish but should be fine for your testing.
Warning: Spoiler!
It did make me notice a couple of issues with the fifth axis...
The following user(s) said Thank You: mariusl, tommylight, Clive S
06 Oct 2023 19:28 #282481 by tommylight
Replied by tommylight on topic QTPlasmaC with six axis
@Phill,
Still on 1366X768 resolution?
To all others, well whoever might do something about it, please do something so Phill can get at least a Full HD monitor!!!
I would gladly donate an Eizo 27" QHD monitor to you, but the shipping will costs about 5-10 times the monitor price, and that aint no cheap monitor.
And, no i do not have any other means of paying besides a bit of crypto i have left. I do have paypal but no card that works with it so it is useless (and paypal has the worst website on planet earth), i do have several credit cards, i had to call the bank every time i wanted to buy something online, so i stopped using those.
Yeah, i know, i live in a s#itty country, but still better than most of the world... does not include Eastern Europe and Japan. No i did not forget USA, it is better for a lot of things, but it is worse for probably the same amount of things!
06 Oct 2023 19:36 #282483 by phillc54
@Phill,
It is all good Tom. I just use that as a worst case.
Thank you for the kind thought.
  • mariusl
  • Platinum Member
  • Platinum Member
08 Oct 2023 10:54 #282548 by mariusl
Warning: Spoiler!
Wow you are a champion man. I will install and test on Monday and I will give you some feedback. It will not be precise testing as we are still working on the kinematics for the 6 axis solution. One of these will be a tube so it's a bit more of a challenge. The bevel cutting on flat plate should already be possible with a kinematics model I just completed for a 17m x 4.5m x 1.8m 5 axis router.
Regards
Marius
www.bluearccnc.com
  • mariusl
  • Platinum Member
  • Platinum Member
08 Oct 2023 11:04 #282549 by mariusl
Rod that should be possible without any extra modules.We already have 5 Axis kinematics that can be slightly modified ( or could work as is ) to make bevel cutting possible.
The bigger challenge will be the post processor to generate the Gcode. At this point in time our only avenue is Fusion or maybe Freecad although I don't know if Freecad has a working 5 Axis solution yet. Because QTPlamac takes care of the probing, it makes the CAM solution a bit easier. It's a one pass cut on the bevelled edge of your part to generate the Gcode. The trick is that the CAM must produce TCP paths.
I hope to simulate some simple cutting process in the week. I will most likely hand code the Gcode to see how QTPlasmac handles it.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.186 seconds
