Trajectory Planner using Ruckig Lib
- RDA
- Thank you received: 43
15 May 2024 20:40 #300697
by RDA
Replied by RDA on topic Trajectory Planner using Ruckig Lib
Yes pleaseSo i could do this for 9 axis. Who thinks this is a thing you should have or not have?
- Grotius
- Thank you received: 2349
15 May 2024 21:52 #300699
by Grotius
Replied by Grotius on topic Trajectory Planner using Ruckig Lib
The following user(s) said Thank You: akb1212, tommylight, Clive S, tivoi, pommen, rodw, spumco, RDA, zmrdko, nwallace and 1 other people also said thanks.
- andrew2085
- Thank you received: 42
16 May 2024 22:24 #300786
by andrew2085
Replied by andrew2085 on topic Trajectory Planner using Ruckig Lib
This is awesome, keep up the good work.
I've been thinking about this kind of stuff lately and have been messing around with path blending ideas, and general trajectory planning and look ahead ideas.
For blending, a cubic curve seems like it would work well. They can be set up to have zero curvature at the ends for joining to lines, or the curvature to match an arc so there's no step in acceleration at a transition. The only problem was I haven't been able to figure out a closed-form expression for the jerk at a given point of the curve at a given velocity. Do you currently have a plan for how you will do blending?
For S-curve planning I found this: assets-eu.researchsquare.com/files/rs-1637727/v1_covered.pdf . I'm not sure if you might find this useful. I put together a Google colab notebook here to try it out: colab.research.google.com/drive/1AkdxP2-...0jYZjW-a?usp=sharing . For P2P or exact stop mode it seems very simple and useful. I haven't figured out if there is an easy way to control the starting and ending velocity while maintaining the same area under the curves. If that is possible it could be very useful.
- Thank you received: 2173
17 May 2024 05:29 #300801
Replied by cmorley on topic Trajectory Planner using Ruckig Lib
Does the jog while pause use multiple command lists ?
That is what Michael Haberler did many years ago.
It never got included in linuxcnc.
I'd love to see your work in linuxcnc.
The following user(s) said Thank You: tommylight, Grotius
- Grotius
18 May 2024 06:50 #300891
by Grotius
@Andrew,
Yeah, after the look ahead is done, i will try to do it with cavaliercontours. If you offset a open contour to 2 sides, then back
to original the path, you get arc blended corners. Then from this, you can filter out the final blended path.
You could offset the x ammount of look ahead lines.
I have seen the docs, it have to dive deeper into that pdf later on in a quite moment. It looks interesting.
My first impression is, it's like a signal filter.
- Grotius
18 May 2024 07:02 #300892
by Grotius
@Mr. Morley,
It only uses a hal pin to emulate a button press. One pin for x+, one pin for x- and so on for each axis.
It's able to move multiple joints together. That's nice.
take a look.
This jog while pausing is coded in less then 3 hours for scurve.
So i think in a few hours you can code it into the original tpmod written by
Rob Ellenberg. You only then have to use the trapezium velocity profile, like the simple_tp jogging.
I used one function in the program loop to check when we are in pause, and velocity is zero.
Then i save the tp position.
Then user may jog the joints. When pause resume is pressed, it is locked until all axis are back at saved position.
take a look.
- Grotius
20 May 2024 09:44 #300994
by Grotius
The look ahead seems to work. It's based on this skeleton code.
It was fucking frustrating designing this code. It seems so simple, but it was not.
It took me day's. In the end i first designed a working skeleton code. Then i was sure faults where
not related to this look ahead skeleton code. From there i calculated the velocity end's for the optimizer
by a trapezium velocity profile. As this is the fastest algo.
Then in the component the skeleton code is integrated as a look_ahead_optimizer .
Then with hal pins you can enable the look ahead and define the nr off look ahead lines.
If no values are given, it sets standard 20 look ahead lines, and standard the look ahead is active.
Then for arc's it uses a integrated velocity optimizer, these settings have to be ported to hal pins too in a later moment.
The perfect arc velocity is now set to radius 5 mm with velocity 1400 mm/min. All other arc velocity's are derived from
this setting.
The component now does not use the grbl's corner algo.
There is a tiny bug when the planner uses end velocity from current segment to next segment. The joint[n]
graph's in the scope show's little transition spikes, however the scurve graph output is ok.
I could not find the problem in a short time, so to solve this,
enable this line. The backend runners will filter the transition spikes out.
this setting.
- Grotius
20 May 2024 13:21 #301003
by Grotius
The video of today.
- Jogging scurve.
- Run sample program.
- Pause, resume.
- Jog while pause.
- Motion reverse.
- Look ahead 20 lines.
Next week i will test it on the production machine.
lcnc scurve source code
- Jogging scurve.
- Pause, resume.
- Jog while pause.
- Motion reverse.
The following user(s) said Thank You: akb1212, tommylight, TangentAudio, pommen, yrsiddhapura, zmrdko, nwallace, Unlogic
- TangentAudio
- Thank you received: 29
20 May 2024 14:23 #301009
by TangentAudio
Replied by TangentAudio on topic Trajectory Planner using Ruckig Lib
Reverse motion might open up the door to replicating the "Traking" feature on Prototrak CNC lathes. It lets you use one of the MPG wheels to move forward or reverse through the program motions.
- andrew2085
20 May 2024 16:06 #301013
by andrew2085
I don't think the FIR s-curve generation will really work for this after messing with it for a while. I have found some papers on s-curve generation with other analytical methods instead of resorting to an iterative solver. It gives a time-optimal solution given the constraints: max velocity, max acceleration, max jerk, path length, starting velocity, and ending velocity. I think this might be much faster than anything else. So far it's looking very promising and its mostly working. There were some errors in the paper that I'm working through.
I think for path blending arcs have to be avoided because there is a curvature discontinuity where they meet a line or different radius arc. It's not possible to limit jerk at the transition unless you come to zero velocity at the transition point. I think the best way to blend a path is using clothoid curves because their radius changes linearly with the curve length which allows curvature continuity which results in smoothly changing acceleration in a transition. There are also algebraic solutions to calculating radial acceleration and jerk at a given velocity and point on the curve. The solutions to fitting the curve to the path geometry are closed-form. I've done a little work on this that I can share soon.
The following user(s) said Thank You: Bari, akb1212, tommylight, rodw, Grotius, DHeineck
Time to create page: 0.347 seconds
