- Thank you received: 4153
Perhaps these values could be added in a seperate custom homing module that is also loaded with HOMEMOD in the ini files. It is posssoble to create new joint pins there (probably axis pins also). I have done this with joint pins. You have already said the simple planner could be integrated with an ini file.Hi Rod,
It is that code for jogging and homing are done outside this trajectory planner. And also adding INI values require
extra code to inihal, inijoint, iniaxis and so on. The lcnc command struct's and other data struct's like nml need a max_jerk value.
