Trajectory Planner using Ruckig Lib
3 years 2 days ago #284133 by Grotius
Thanks all so far, for your kindness !
@ MichalHK,
For any money transfers we can make a donation entry later on the road.
I am not the only coder in this project.
Today we made the motion reverse.
It took me the whole day. But it works excellent now.
User's feed & rapid overrides are also in.
To enable the motion reverse, it's just setting a boolean hal pin "false or true".
Ok, now the "look ahead" has to be coded.
But first i will maka a few short video's
how the program already works at this stage.
@Tommy,
Glad you are busy with the repair work. Please be carefull with the stuff.
The following user(s) said Thank You: akb1212, tommylight, tivoi, pommen, Beef
3 years 1 day ago #284171 by Grotius
Hi Guy's,
The video's are ready.
  • forward run
  • reverse run
  • pause
  • resume
  • max velocity
  • feed overide
  • rapid overide
  • mode mdi
  • mode auto
  • mode manual
  • homing
The video's are also on github : github.com/grotius-cnc/linuxcnc/releases/tag/1.1
The following user(s) said Thank You: akb1212, tommylight, Clive S, tivoi, pommen, rodw, Joco, spumco, JacobRush, MennilTossFlykune and 3 other people also said thanks.
2 years 11 months ago - 2 years 11 months ago #284299 by Joco
Hello.  I tried building the 1.0 tar ball but hitting some issues:
Needed add in an extra dependency:
libboost-python-dev
Then hit this issue.   the linuxcnc uspace dev package is installed.  Ideas? Suggestions?
Warning: Spoiler!
Last edit: 2 years 11 months ago by Joco. Reason: Cleaning up so not as space hungry
The following user(s) said Thank You: Beef
2 years 11 months ago - 2 years 11 months ago #284303 by Beef
Most likely it's not finding the config.h related to libboost-python-dev properly. Can you throw an issue on github ( github.com/grotius-cnc/linuxcnc/issues ) and I'll track it down?
Last edit: 2 years 11 months ago by Beef.
The following user(s) said Thank You: rodw, Grotius
2 years 11 months ago #284336 by Grotius
The joco error is a little strange.
But to solve other build errors, i did a made a few changes to the source.
Maybe just try out again to clone and build :
$ git clone github.com/grotius-cnc/linuxcnc.git linuxcnc
$ cd linuxcnc
$ cd cmake
$ ./build_all
I Just tested this ok, linuxcnc started after build. And now with "sudo make setuid" included.
2 years 11 months ago #284355 by JPL
  • mode mdi
  • mode auto    <<<<
  • mode manual  <<<<
I may be wrong (or is it just wishful thinking?) but the second video seems to suggest that jog while paused is possible with this new TP ?!?
Time to create page: 0.708 seconds
