- Thank you received: 905
Control panel hardware buttons
2 years 9 months ago #290986
by spumco
Replied by spumco on topic Control panel hardware buttons
2 years 9 months ago #290987
by spumco
2 years 9 months ago #291072
by blazini36
Replied by blazini36 on topic Control panel hardware buttons
Sure it is, but that doesn't look very sturdy. I have that keyboard, I used to use it in my living room. I broke the micro-USB port so many times I couldn't solder it on anymore.
I could do it with the hinges I have if I wanted. The problem (I was alluding is now I have slots in an otherwise seal-able enclosure to pass hinges out of.
I'm trying to figure out what the point is, just aesthetics right? I don't think that looks better.
2 years 9 months ago #291085
by spumco
The keyboard was just a quicky d/l from grabcad. If I were doing it myself, I'd probably use a panel-mounted keyboard and put a thin gasket on the back. Then it'd sit on the outer surface and be chip/splash resistant when the keyboard was folded up (keyboard panel would form a bezel).
My intent was to show a main enclosure that is easier to fabricate than the notched one, as well as not needing to fabricate a separate keyboard 'box'. The whole enclosure would be a simple box with three openings (monitor, control btns, keyboard).
Looks, of course, are totally subjective.
2 years 9 months ago #291092
by blazini36
What about the big gaping hole? Just wall it off and lose whatever space is behind it?
I plan to stick a PCB in there, that's not really a good look when the keyboard is open. Even still why wouldn't I just use the rotating hinge I have now? If I wanted to do that I'd just make the overall shape more circular, like a hook to take up less space.......
2 years 9 months ago #291107
by RDA
Replied by RDA on topic Control panel hardware buttons
Does the keyboard need to be visible when ”closed”? I mean I assume its quite akward to use in the closed position.
So of it can be hidden, I would do a simple hinge in the bottom and then put a couple magnets on the top to ”lock” it closed.
Time to create page: 0.220 seconds
