- Thank you received: 167
Control panel hardware buttons
2 years 9 months ago #289775
by blazini36
Replied by blazini36 on topic Control panel hardware buttons
3mm? Holy smokes....that's 11 gauge. Ford Rangers used 10-11 gauge in their frames lol, I know I built one.
- my1987toyota
- Thank you received: 449
2 years 9 months ago #289805
by my1987toyota
Replied by my1987toyota on topic Control panel hardware buttons
Yeah but at least if you're having a bad and throw something at it, it wont hurt any thing. Not that I have ever done that.image missing /media/kunena/emoticons/whistling.png
2 years 9 months ago #289837
Replied by rodw on topic Control panel hardware buttons
MAybe Something like this.
I have an Odroid H2+ PC inside.
Be sure you get a 1080p monitor so you can use Probe_basic or qtdragon_hd
I had to shoehorn a different monitor in because my earlier 15.6 inch screen was not 1080p. Monitoe is from greentouch and I found them very reaonably priced with hepas of options but this was the only one I could make work (with an angle grinder).
There is an estop reset button on the side of the case to keep the front clutter free.
The following user(s) said Thank You: Mr Moo
2 years 9 months ago #289879
by blazini36
2 years 9 months ago #289923
BE sure to install the r8168-dkms driver ofr the H2/H3
Also there are some settings now that let NIC's go to sleep. I cant remember what disales it, but I suspect it may be an issue with the H3
I thought about industrial keyboards but ended up using a cheap wireless keyboard you can put away somewhere until you need it.
2 years 9 months ago #289942
by blazini36
Only problem Ive run into on an H3 is the bios it ships with, I didn't think to update it on one and had a bunch of latency issues until I did.
Time to create page: 0.215 seconds
