Control panel hardware buttons
2 years 7 months ago - 2 years 7 months ago #295071 by blazini36
I wonder if you couldn't use a membrane keyboard with an adhesive printed overlay? might help get the cost down.
What kind of adhesive overlay sticks to rubber and will hold up?
The purpose of these buttons was I wanted to just print clear labels from a Dymo and stick them under the clear keycaps. I can do that with these, they're just a bit more difficult to deal with than I like
I just heard back from the place that makes the rubber membranes, the membranes themselves are cheap if using the standard off the shelf ones but I'd have to pay $250 for a printing plate to get the rubber keys printed on. Probably going to pass on that idea for now. Maybe I'll stick with these buttons, they aren't that expensive now that I look at the order. It's just a bit harder to make this keypad than I like.
Last edit: 2 years 7 months ago by blazini36.
2 years 7 months ago #295075 by rodw
Replied by rodw on topic Control panel hardware buttons
I think the correct term I should have used is a tactile switch array.
Something like  udvabony.com/product/tactile-switch-4x4-...-16-keypad-keyboard/
You could also build this yourself. You may need to cut a grid of holes in your enclosure.
Then in CAD, design the adhesive overlay that is applied over the buttons. (Don't forget to include Mr Chips!)
Discuss the available substrates to print on with your local digital printer.
I have some permanent adhesive polyester roll fed barcode labels that I can print on with a Zebra barcode printer using a permanaent ribbon.
The stuff is thin, flexible and indestructable. I use it for compliance labels for automotive products. There will be something similar in the signage industry.
You do see what I am suggesting used a lot on electronic products.
2 years 7 months ago #295076 by rodw
Forgot to mention signwriters can also laminate the panel after they print it.
2 years 7 months ago #295088 by blazini36
What you're actually suggesting is what mechanix suggested earlier in the thread, a dome switch keypad. That is what is used with the plastic overlay you see in many industial applications. They don't use tactile switches, they use domes. Again the problem is A) cost and B) it's once it's printed, that's what you have.....it's not further configureable but the "user"
2 years 6 months ago #299303 by Mr Moo
Hello All,
Sorry for hijacking the thread slightly....
@ Rodw   Could you send me a link to more info about the Mill conversion shown in this image please?
Many Thanks
2 years 6 months ago #299306 by rodw
Hello All,
Many Thanks
Sorry, I just got in and got it done so there is not really a thread anywhere. It works quite well. Ethercat hardware.
Time to create page: 0.305 seconds
