error finishing read and joint following error.
  • jg00163206
  • jg00163206's Avatar Topic Author
  • Premium Member
  • Premium Member
29 May 2024 18:23 #301762 by jg00163206
******Dr. Emmit Brown***** "IT WORKS........IT WORKS! i finally invented something that works."
Greetings, i finally got a working configuration on my dell vostro desktop but I am getting error finishing read and then a joint 0 following error. even after i disabled all the virtualization options in bios and i did the irq balance according to this link forum.linuxcnc.org/38-general-linuxcnc-q...ead-and-irq-affinity .this is only an issue on this machine. it works perfectly on a duo core laptop but i can't get it stable on the the desktop. i did read a post that said if i update the rtkernel to something above 6.1 to something like 6.3 that it might fix that issue but i am unsure on how to do that exactly? Tried to compile a kernel according to the instructions on myheap.com but i keep getting a make error and i shouldn't have to compile a whole kernel just to update to a newer version do i? you guys on this site have been amazing already with helping me get this machine working and any help you can offer on this issue will be greatly appreciated.
I'm running a Dell Vosrto with an i5 3.4ghz cpu with dual intel Ethernet cards,  right now there is firepro gpu in it. i'm on linuxcnc 2.9.2 with 6.1.1 rtkernel.
29 May 2024 18:48 - 29 May 2024 18:56 #301763 by PCW
Can you run this script to check the IRQ pinning and
kernel command line setting:
File Name: checkmask_...5-29.txt
File Size:1 KB
Also since you have Intel MACs, have you disabled IRQ coalescing?
(man hm2_eth)
Last edit: 29 May 2024 18:56 by PCW.
  • jg00163206
  • Premium Member
  • Premium Member
30 May 2024 01:40 #301793 by jg00163206
Replied by jg00163206 on topic error finishing read and joint following error.
i will run that script tomorrow when im in front of it. are you referring to the hardware coalescing in /etc/network/interfaces? (or something of like that) add that last line from (man hm2_eth) to that file?
  • jg00163206
  • Premium Member
  • Premium Member
30 May 2024 01:45 #301795 by jg00163206
hardware-irq-coalesce-rx-usecs 0 this line right here?
  • jg00163206
  • Premium Member
  • Premium Member
30 May 2024 16:04 #301852 by jg00163206
mill@4axis:~$ sudo ./checkmask_...5-29.txt enp5s0
Cores: 4
Actual CPU Mask: 7
Desired CPU Mask: 8
IRQ: 30
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-21-rt-amd64 root=UUID=88090a82-c4aa-4670-a115-b8c1ff4ac64c ro initrd=/install/gtk/initrd.gz quiet isolcpus=3 intel_idle.max_cstate=1 i915.enable_rc6=0
  • jg00163206
  • Premium Member
  • Premium Member
30 May 2024 16:20 #301855 by jg00163206
totay i can't ping the mesa board @ 10.10.10.10.
yesterday i could at least jog for a second
30 May 2024 16:27 #301856 by PCW
What does:
ip a
report?
  • jg00163206
  • Premium Member
  • Premium Member
30 May 2024 16:32 #301859 by jg00163206
should that i915 be there? i seem to remember reading something about that in this forum somewhere. this what i get in the error report, hm2_eth: rtapi_app_main: Connection refused (-111)
today i deleted the connection i created and configured the network frome the interfaces file.
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The Mesa 7i96s FPGA card interface
auto enp5s0
iface enp5s0 inet static
address 10.10.10.10
30 May 2024 16:52 #301860 by PCW
You have the IP address of the host = the card IP address
This cannot work. I would suggest setting the host address
to 10.10.10.100
  • jg00163206
  • Premium Member
  • Premium Member
30 May 2024 17:54 #301868 by jg00163206
okay, did that, i can at least ping it and jog for one second and then get the same errors. error finishing read and joint 0 following error.
Time to create page: 0.127 seconds
