error finishing read and joint following error.
- Thank you received: 5321
30 May 2024 18:08 #301872
Replied by PCW on topic error finishing read and joint following error.
Its clear that the IRQ pinning did not work so can
you try running this script and re-trying LinuxCNC?
(look at it first, never run a script especially one you must run as root
without a careful examination)
chmod +x pinirq.txt
then
sudo ./pinirq.txt enp5s0
linuxcnc
chmod +x pinirq.txt
then
linuxcnc
- jg00163206
- Thank you received: 4
31 May 2024 19:35 #301988
by jg00163206
Replied by jg00163206 on topic error finishing read and joint following error.
sorry i missed this but ip a reports;
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 00:e0:4c:68:0e:4f brd ff:ff:ff:ff:ff:ff
inet 10.0.0.5/24 brd 10.0.0.255 scope global dynamic noprefixroute enp4s0
valid_lft 84042sec preferred_lft 84042sec
inet6 fe80::2e0:4cff:fe68:e4f/64 scope link noprefixroute
3: enp5s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether a4:1f:72:67:47:1f brd ff:ff:ff:ff:ff:ff
inet 10.10.10.100/8 brd 10.255.255.255 scope global enp5s0
4: wlp3s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 3e:d9:0d:5b:18:2b brd ff:ff:ff:ff:ff:ff permaddr 9c:2a:70:32:72:49
31 May 2024 19:51 #301993
Did you try the pinirq script?
Note: it will only pin the IRQ temporarily unless you disable irqbalance
- jg00163206
31 May 2024 20:06 #301997
by jg00163206
yes i did. i am unable to ping the board and i have a watchdog bite error. i also ran checkmask again and the IRQ changed from 30 to 29
- jg00163206
31 May 2024 21:09 #302004
by jg00163206
i don't understand why i can't connect to the 7i96s now. when i run mesaflash --addr 10.10.10.10 --device=ETHER --readhmid it tells me there is no board found. and pncconf can't find the board either. or even mesaflash --device 7i96s --addr 10.10.10.10 --readhmid , no 7i96s found.
31 May 2024 21:53 #302009
What does "ip a" report now?
- jg00163206
31 May 2024 22:58 #302015
by jg00163206
it reports the same as before. i don't know what the deal with that computer is. linuxcnc runs flawlessly on the duo-core laptop and i think thats what i am gong to use for now. i have been messing with this computer for a month at least trying to get linuxcnc working on it and it just doesn't want to work. for whatever reason. i gonna just use the laptop and that will be its only job, running linuxcnc, which it does very well. i just want to start using my machine, and the longer i mess with that desktop, its time i am not milling. i appreciate all your help. ill put it on the back burner for now and maybe i will visit it again in the futrure. thank you very much for you knowledge and patients. i WILL need your expertise again.
31 May 2024 23:11 #302017
Note that this overlaps your other address:
Allowing a normal internet packet to get routed out of the real time interface
Not sure that would cause your issues but you might try setting enp5s0's netmask
to /24 (so 10.10.10.255) rather than /8 (10.255.255.255)
The following user(s) said Thank You: jg00163206
- jg00163206
03 Jun 2024 03:16 #302216
by jg00163206
how would i do that exactly? through edit connections? the same way i created the connection?
- jg00163206
03 Jun 2024 03:19 #302217
by jg00163206
sorry, i understand after looking at it for a few minutes. i will give it try. thank you.
Time to create page: 0.155 seconds
