error finishing read and joint following error.
- jg00163206
- Thank you received: 4
02 Jul 2024 19:02 #304267
by jg00163206
Replied by jg00163206 on topic error finishing read and joint following error.
what isolcpus settings do i need for an 8 core ryzen machine?
- Online
- Thank you received: 5321
02 Jul 2024 19:19 - 02 Jul 2024 19:20 #304269
Replied by PCW on topic error finishing read and joint following error.
isolcpus=7
Note that if you have ~10 ms latency this is not likely to be fixed by isolcpus
Did you install the Realtek DKMS driver?
If you did, what are the current results of the ping test?
Last edit: 02 Jul 2024 19:20 by PCW.
- jg00163206
02 Jul 2024 21:21 #304273
by jg00163206
Absolutely brilliant. thats the ticket right there. even without isolcups. its been running for several hours now and i haven't gotten the dreaded error finishing read error.
- jg00163206
02 Jul 2024 21:23 #304274
by jg00163206
i have not installed everything yet. i will get to that and let you know how the latency is after running it for a day or so. thank both of you for all your help.
- Thank you received: 7468
02 Jul 2024 21:42 #304276
Replied by tommylight on topic error finishing read and joint following error.
I use Ryzen 7 3700X CPU, never had to do isolcpu, it just works. Same on Ryzen 5 3600.what isolcpus settings do i need for an 8 core ryzen machine?
- jg00163206
02 Jul 2024 23:05 #304280
by jg00163206
it does work. i was just about to do it until you told me that thanks. are there any drawbacks to doing it anyway?
02 Jul 2024 23:47 #304285
Not that i know of from reading here, but i have never used isolation, ever, i have access to plenty of PC's and laptops so if any show bad latency i run 3D printers from it!
- jg00163206
04 Jul 2024 18:31 #304409
by jg00163206
I'm getting this error now when i update.
W: Skipping acquire of configured file '2.9-rt/source/Sources' as repository 'www.linuxcnc.org bookworm InRelease' does not seem to provide it (sources.list entry misspelt?)
- jg00163206
04 Jul 2024 18:33 #304410
by jg00163206
also, in step 32 there is an extra : that gets an error if you are cut/pasting the commands.
Time to create page: 0.124 seconds
