- Thank you received: 599
Linuxcnc 2.8.4 does not show tandem items.
- JT
2 years 4 months ago - 2 years 4 months ago #303271
by JT
Replied by JT on topic Linuxcnc 2.8.4 does not show tandem items.
Looks like Phil added tandem joints about 3 years ago to the 2.9 branch.
github.com/LinuxCNC/linuxcnc/commit/f213...27a402ba6ec66ea54dfc
JT
JT
Last edit: 2 years 4 months ago by JT.
The following user(s) said Thank You: aparecido
- aparecido
- Thank you received: 6
2 years 4 months ago - 2 years 4 months ago #303272
by aparecido
Here on the forum there are some topics about an ethernet card with ESP32 that is being tested/developed in open source to be able to use linuxcnc on PCs that no longer have a parallel port, suddenly in future Stepconf updates, they end up including the Esp32 option when all has already been developed/tested and published in the topic, it would also be of great help.
Replied by aparecido on topic Linuxcnc 2.8.4 does not show tandem items.
Yes, from what I understand by looking at the posts here on the forum, these options were first found in Pnfconf and then went to Stepconf as well.I see that now, thanks for clarifying that for me... looks like someone has been working on the Stepconf tool.
JT
Last edit: 2 years 4 months ago by aparecido.
- aparecido
2 years 4 months ago #303273
by aparecido
Hmmm interesting, so if I didn't understand it wrong, the 'tandem function' is only really implemented in stepconf and in the files generated by it from version 2.9.* onwards....Looks like Phil added tandem joints about 3 years ago to the 2.9 branch.
JT
- JT
2 years 4 months ago #303276
by JT
JT
That's correct, I changed to the 2.8 branch to see and the tandem function is not in that branch.
JT
JT
- aparecido
2 years 4 months ago #303301
by aparecido
Well, as there is no way to update the Linuxcnc version, is there any other way to manually configure the INI and Hal to square the gantry using two motors and two sensors on the same axis?
- JT
2 years 4 months ago #303302
by JT
linuxcnc.org/docs/stable/html/config/ini...l#sec:homing-section
JT
Yes, you just need to set the home sequence to a negative number.Well, as there is no way to update the Linuxcnc version, is there any other way to manually configure the INI and Hal to square the gantry using two motors and two sensors on the same axis?
JT
Time to create page: 0.257 seconds
