- Thank you received: 6
Linuxcnc 2.8.4 does not show tandem items.
- aparecido
2 years 4 months ago #303781
by aparecido
Replied by aparecido on topic Linuxcnc 2.8.4 does not show tandem items.
So with this configuration I need to do homming to release movement, right? Before, in the standard configuration of 3 motors, I moved the machine before homing without any problems...You need to Home all before attempting to jog
If you don't have home switches, you will need to add them for a gantry as they are mandatory.
- Thank you received: 4153
2 years 4 months ago #303783
Replied by rodw on topic Linuxcnc 2.8.4 does not show tandem items.
The joint axes that were added in 2.8 require homing before jogging as your error says.
I just got into the habit of hitting home all after power up so its not onerous and generally not difficult to add the required switches.
The following user(s) said Thank You: aparecido
- aparecido
2 years 4 months ago #303786
by aparecido
In the machine and in the old configuration of this machine that I built now, before using two sensors to square, I had the habit of doing the homing with the inductive sensors on the axes.
But as in the previous format I was able to move the axes before homming, I found it strange that I tried to do the same now and the error message appeared.
I will do new tests as soon as possible, thank you for the information and help.
Got it, interesting.The joint axes that were added in 2.8 require homing before jogging as your error says.
- aparecido
2 years 4 months ago #303832
by aparecido
Hi guys, good news, the homming square worked perfectly.
I already backed up hal and ini so I wouldn't have any more problems...
I have a new question, is it possible to jog any of the axes before homming?
Because imagine that for some reason Linux closes or the PC restarts with the axis stopped at the other end, the travel of Y and X is approximately 1000mm, when I give the homming command it slowly comes looking for point 0 (sensor) . Before, when I could move the motors before homing it was quick, I would bring it close to the jog sensor and give the homming command, but now I have to wait a long time....
Is there a way to get around it?
2 years 4 months ago #303848
Have a look at the homing veocities
linuxcnc.org/docs/stable/html/config/ini...tml#_home_search_vel
As the docs say there is trade off between homing speed and overrun.
From memory I use search_vel 12 m/min and placed the home switch far enough away from the limit switch so the axis could coast to a stop
Then a much slower latch velocity to find the home switch edge
Finally a home_offset (of about 40mm) to move close to the limit switch to maximize the machine envelope
Whilst you can use a shared home/limit switch, and this works fine where there is some weight being moved (eg milling machine table) so the axis stops quickly, a lightweight gantry might be better off with seperate switches so you can home at speed.
- aparecido
2 years 4 months ago #303921
by aparecido
One more question, when I give the home all command, does it homing to Y and homing to the Z axis and then to Y and finally to X1+X2?
The initial sequence is configured like this:
Z axis = 0
Y axis = 1
X1 axis = -1
X2 axis = -1
Ah ok, I'll test it at other speeds to see how it behaves.Have a look at the homing veocities
Z axis = 0
Y axis = 1
X1 axis = -1
X2 axis = -1
Time to create page: 0.136 seconds
