Getting an error on starting a machine
18 Aug 2024 16:48 #308088 by __Tom
Replied by __Tom on topic Getting an error on starting a machine
I changed the PC addr. to 11, same behave as before, no succ.
18 Aug 2024 17:00 - 18 Aug 2024 17:01 #308090 by Aciera
Replied by Aciera on topic Getting an error on starting a machine
Just to be on the same page you changed the PC IP-address to this?
10.10.10.11
Last edit: 18 Aug 2024 17:01 by Aciera.
18 Aug 2024 17:08 #308091 by __Tom
yes to 10.10.10.11
18 Aug 2024 17:57 #308098 by PCW
Replied by PCW on topic Getting an error on starting a machine
The lack of yellow (100BT) LED illuminated the RJ45
suggests a problem with the 7I76E Ethernet interface
or the host Ethernet interface.
I would try a known working  Ethernet connection, and if you
do not get both Green (activity) and Yellow (100BT) LEDs
illuminated on the 7I76E RJ45 connection, I would return the
7I76E  for warranty repair. Note that especially for plasma systems
it's important to ground the frame ground connection on the 7I76E.
  • Moderator
  • Moderator
18 Aug 2024 18:52 #308103 by tommylight
Replied by tommylight on topic Getting an error on starting a machine
ip a
If you only changed from 10 to 11 it will not work
Change to 10.10.10.11
19 Aug 2024 05:33 #308114 by __Tom
Thanks a lot for your afford.
