First time linux cnc user - no stepper movement.
- crazycajun
05 Sep 2024 16:26 - 05 Sep 2024 16:36 #309430
by crazycajun
First time linux cnc user - no stepper movement. was created by crazycajun
I cam from a "working" mach3/uc100 setup over to a 7i96s setup. K4030 drivers. terminal pings the mesa board. I have dir +/- and step +/- wired to the k4030 and 7i96s. a cell phone charger to power the 5v of the 7i96s.
steppers dont move. i have no limit switches hooked up yet and i configured the settings to not need to home first.
i tried connecting the 24/36v psu ground to com on the 7i96s, i tried connecting the 7i96s 5v to the dir + & step + (which is how mach3 was configured; and the dir/step - was 2 pins on the serial board).
when i connected 5v to dir/step +, and started linuxcnc, i did get "unexpected real time delay on task0 with period 1000000"
what do i have wrong?
once i get this figured out im going to make a video on all of this to help me next time and others. i have been on the struggle bus thus far.
side note, with just the 5v input and dir/step +/- hooked up, i get 5.09v between gnd & 5v, i get 5.09v between step + & gnd, i get .23v between dir - & gnd, and dir + to gnd i get 4.81v. on unused step/dir ports its the same except i dont get the .23v reading, its 0 instead.
Last edit: 05 Sep 2024 16:36 by crazycajun. Reason: added voltage readings.
- Thank you received: 5330
05 Sep 2024 16:44 #309433
Replied by PCW on topic First time linux cnc user - no stepper movement.
Most common issue with no motion is too short step times
I would set the step length to say 5000 and try again
- crazycajun
05 Sep 2024 16:44 #309434
by crazycajun
Replied by crazycajun on topic First time linux cnc user - no stepper movement.
also, i am on kernel 6.1.0-7-rt-amd64 with an inspiron 545s
- crazycajun
05 Sep 2024 16:46 #309435
by crazycajun
i set the step to 32000 like i had it in mach3. is that too short?
- crazycajun
05 Sep 2024 16:55 #309436
by crazycajun
i set the calculated steps from 32000 to 5000, no change in operation.
05 Sep 2024 18:10 #309442
Not calculated steps, but the steplength parameter
- crazycajun
05 Sep 2024 18:18 #309444
by crazycajun
thats the one with the drop down box for different drivers correct? if so i selected the k 4030
05 Sep 2024 18:43 #309445
The critical one would be the "Step-On time" parameter
- crazycajun
05 Sep 2024 19:16 - 05 Sep 2024 19:28 #309456
by crazycajun
Last edit: 05 Sep 2024 19:28 by crazycajun.
- crazycajun
05 Sep 2024 19:47 #309460
by crazycajun
is it possible that the cell phone adapter power is the issue? i have a L7805CV L7805 Positive Voltage Regulator Output 5v TO-220, can i use one to power the mesa?
Time to create page: 0.176 seconds
