Parse Error
- acourtjester
- Thank you received: 29
12 Oct 2024 19:56 #311896
by acourtjester
Parse Error was created by acourtjester
HiI an trying to get setup to use a router on my CNC table. I have it setup for plasma with QTPlasmaC and things are great. Now I want to start doing router work and have set up Axis, smoothed over a few bumps. But I am still getting an error (Parse_FILE_INTERP_ERROR) and cannot find an answer with Google, so here I am.I home the table then move to a location away from home and click on “Touch off” it brings up a menu with 0.0 in the window. I leave it on P0 and click on Ok and then I get the error. I get the same error for each axis. It does not matter if I touch off at the home location, I get the same error there too. This is the procedure I used with other tables and software, and I am just starting with LinuxCNC Axis.If I X out the error message and then can run the G-code I have loaded.
- Thank you received: 2176
13 Oct 2024 12:41 - 13 Oct 2024 12:43 #311960
Replied by Aciera on topic Parse Error
Last edit: 13 Oct 2024 12:43 by Aciera.
- acourtjester
13 Oct 2024 15:19 #311975
by acourtjester
Replied by acourtjester on topic Parse Error
Thanks for the reply but I'm not well versed in linuxCNC and was looking for how to stop it from happening.
What do I change or add?????
13 Oct 2024 16:45 - 13 Oct 2024 16:59 #311988
Open a terminal application (from the main desktop menu or try keyboard shortcut 'Ctrl'+'Alt'+'t') and type 'linuxcnc' (and press enter/return) then that should open the config picker and you can select your machine config. Then check the output in the terminal window once the error has occured and copy/paste that here.
Last edit: 13 Oct 2024 16:59 by Aciera.
- acourtjester
13 Oct 2024 16:53 #311990
by acourtjester
Thanks will do in the morning
- acourtjester
13 Oct 2024 19:12 #312003
by acourtjester
I think this is what you wanted did not see an output or copy of the terminal window so I screen shot it. I also attached the G-code but had the error with out loading it.
Thanks for your time
14 Oct 2024 07:09 #312039
Not sure, I have no issues loading your gcode (after changing the extension from '.tap' to '.ngc'). Do you maybe have a python filter script set for .tap files?
- acourtjester
14 Oct 2024 19:09 #312091
by acourtjester
Ok made progress I can load a G-code created with EstlCam and move the table to any location and touch off and run the g-code without a problem. I cannot load or run a G-code created with SheetCam even with a NGC file type. I did some changing in the INI file and had other errors, I attached some PDF files with info and screen shots of the error messages I got and the 2 NGC files.
Thanks for your time hope you have more good info in a reply.
- Thank you received: 7488
14 Oct 2024 19:39 #312093
Replied by tommylight on topic Parse Error
Hal_plasmac_cut_feedrate is a plasma variable, but the GUI is not PlasmaC nor QtPlasmaC, so what gives?
- acourtjester
14 Oct 2024 21:18 #312101
by acourtjester
Not plasma at all I an using Axis for a router Only mentioned QTPlasmaC in passing. I got great help with that and now have moved on to Axis and routing.
This is only for Axis.
Time to create page: 0.265 seconds
