- Thank you received: 22
Fast Hole EDM from Hacked Parts
- IronManDylan
1 year 11 months ago #315162
by IronManDylan
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
Hey Tommy,
Thanks. I actually just got a response from Peter. He gave me the same link you gave me but told me there is a firmware that already has the modifications that I need. It's called 7i96s_pmd.bin. So it seems that as long as I can get this to flash I should be good to go as far as listening to the PWM from the Powercore from Rack Robo goes.
Assss long as the Mesa board can pick up a 3.3v signal on that pin. It seems that is what the Powercore is putting out as its PWM signal. I can also ask Peter about this and worst case I can run the input into a MOSFET or something similar to up the voltage into the Mesa...
Best,
-Dylan
Best,
-Dylan
The following user(s) said Thank You: PCW
- Thank you received: 2177
1 year 11 months ago #315169
Replied by Aciera on topic Fast Hole EDM from Hacked Parts
SPAM removed.
- Thank you received: 5334
1 year 11 months ago #315178
Replied by PCW on topic Fast Hole EDM from Hacked Parts
The 7I96S encoder inputs have a 1.65V threshold when jumpered for TTL mode
so will work with a 3.3V input. They do have a 2K Ohm pull-up resistor to +5V,
but this should be OK if the 3.3V output is push-pull.
- IronManDylan
1 year 11 months ago #315183
by IronManDylan
Hi PCW,
Sorry I am unfamiliar with the terms that you are using.
It seems that TTL mode is transistor-transistor logic? Is this the mode the board should be operating in? Even after the firmware update?
And push-pull means that there is a mosfet or transistor opening the input to ground when the pulse is off/low, correct? I guess this makes sense with a pull up resistor, now sure why they would have one there.. And then obviously high when the pulse is on. I do not know if this is how the Powercore is wired. Honestly, all I know right now is that there are two wires coming off the ALRT pin from the Powercore, I am assuming one of them needs to be tied to ground and the other is the PWM pin. I think there is a schematic online I can look at and try to find out.
If the board can run off the 3.3v straight from the Powercore that would be great, if not I can figure out what I need to change and make a little circuit. Wether thats a push-pull circuit or with a simple pull-down resistor. I can also increase the voltage if I do that..
Thank you.
Best,
-Dylan
Thank you.
Best,
-Dylan
1 year 11 months ago #315188
The 7I96S encoder inputs have 2 modes: differential = RS-422 and single-ended = TTL
These modes are set by jumpers on the 7I96S card, one per input. If you do not have
differential signals (and it sounds like you do not) the index input must be jumpered for
TTL mode. (These jumper settings are described in the 7I96S manual)
Its most likely the 3.3V output signal is push-pull, The reason for caution is that is it is not push-pull
it may get pulled up to 5V by the 2K pullup resistor at the 7I96S input.
- IronManDylan
1 year 11 months ago #315216
by IronManDylan
PCW,
Okay, I do not have the board in front of me right now so I can't say for sure, but I have not modified anything on my board so if the jumpers came installed stock then that is how they are now. Btw, I assume that "jumpers" are just connectors connecting two different points on the board and are used to control the logic, yes?
And okay, I see what you are saying. I will plan on testing with the ALRT pined directly into the input (on pin 29). If I have any issue reading the signal I will revisit this.
Thank you.
Now I am going to start trying to put the code together so I can test as soon as I am home.
Best,
-Dylan
Thank you.
Best,
-Dylan
Time to create page: 0.314 seconds
