- Thank you received: 22
Fast Hole EDM from Hacked Parts
- IronManDylan
1 year 10 months ago - 1 year 10 months ago #317004
by IronManDylan
Replied by IronManDylan on topic Fast Hole EDM from Hacked Parts
I am back. I got very busy and got sick and have just now been able to get to the software side of things. I added a picture of the pumps I am using because that is kind of fun.
But I am having trouble connecting to my board using Mesaflash. It seems like this is not an uncommon problem for people to have, but despite reading the multiple forum post about this issue I am unable to find a solution that works for me. I am getting the error "No **** board found" I have tried every board name I can think of but nothing is working. I currently have a 7i96s and a 7i85s linked together, so I assume the board name is a combination of these two. There doesn't seem to be a way to see what board is connected..
A note about the 7i85s. At one point I had 6 drivers connected to my machine, which is why I needed the 7i85s. However, I am no longer using all the boards. One of my drivers is still connected to the 7i85s but I can move it to the 7i96s. I am saying all this because I am assuming that the new firmware (the 7i96s_pmd.bin) will not work with the 7i85s connected. I am assuming this because of the name..
Anyway. Can someone please help me figure out how to get in communication with the board I have. I am talking to it through an ethernet cable, I don't know how to tell the terminal that that is how I am communicating though.. I have tried both 10.10.10.10 and 192.168.1.121.
Last edit: 1 year 10 months ago by IronManDylan.
- IronManDylan
1 year 10 months ago #317011
by IronManDylan
Update. Want to post this before I bothered anyone with a response. Was able to get connected. I had 7i92 instead of 7i96. Obviously this was the problem. I will post again when and if I hit the next sang. Thank you.
- IronManDylan
1 year 10 months ago #317024
by IronManDylan
So I spent the rest of the day trying to figure out how to get a gcode command to turn a relay on and off using the output pin from the mesa 7i96s. The relay controls the pumps and it needs to be turned on before I start EDMing. I think getting a simple relay to work before trying to mess with a PID loop is best. I am not sure if it is relevant but the pin is TB3 pin 14 based on the mesa 7i96s manual.
I believe what I need to do is have a user defined mcode (this allows me to easily turn the pumps on and off and I can also modify my gcode post processor to turn this off and on after I output any drilling operations). The name of the file is M101. I will also write a M102 to turn the pumps off once I get this first one working. And btw this is just placed in the main folder that is this machine. Here is what is in the M101 file:
#!/bin/bash
halcmd setp motion.digital-out-00 true
chmod +x M101
exit 0
I am also trying to modify the .hal file to actually call up the mcode command. Here is what I have in the .hal file:
setp hm2_7i96.0.output.00 true
net edm-pump-output <= motion.digital-out-00
net edm-pump-output => hm2_7i96.0.output.00 true
Something is not right though because I am getting the debug error "paramater or pin 'hm2_7i96.0.output.00' not found" and the machine won't boot up (I did get it to boot up after flashing though).
I am going to look at this with fresh eyes in the morning. But this is not an area I am proficient in and I am not finding a webpage that clearly lays out the syntax. I get that the pin needs to be set, and then connected. But I really do not know how to do that. So if someone would be willing to point out what I have wrong I would really really appreciate it.
Thank you.
Best,
-Dylan
#!/bin/bash
chmod +x M101
exit 0
Thank you.
Best,
-Dylan
- Thank you received: 2177
1 year 10 months ago #317033
Replied by Aciera on topic Fast Hole EDM from Hacked Parts
1. This makes no sense in your custom mcode as the file needs to be executable in the first place
2. comment out those 3 lines in your hal file, start your config and use the 'show halconfiguration' tool to check for the correct pin descriptor.
chmod +x M101
- IronManDylan
1 year 10 months ago - 1 year 10 months ago #317057
by IronManDylan
Aciera,
Okay, I just messed with the machine for over an hour and I am more confused now than at the beginning. I assume you are trying to get me to find the correct pin using the hal configuration tool. Well. I could not find the pin. The only place that seemed reasonable was under GPIO. I set all these pins to high using hal configuration. Nothing I did turned my pump relay on (I was also checking with a multimeter). Btw, I got to hal configuration from the GUI, not from terminal, I assume this wouldn't change anything.. It is frustrating that there is not a document somewhere that shows the names of the pins as LinuxCNC has them named...
I am not surprised that my mcode does not make sense, are you saying that I need to remove "chmod x M101"?
Thank you.
Best,
-Dylan
Thank you.
Best,
-Dylan
- Thank you received: 5334
1 year 10 months ago - 1 year 10 months ago #317058
Replied by PCW on topic Fast Hole EDM from Hacked Parts
Last edit: 1 year 10 months ago by PCW.
Time to create page: 0.678 seconds
