Real-Time Kernel with Orange Pi 4 LTS
- royka
- Thank you received: 135
24 Nov 2024 11:25 - 24 Nov 2024 12:51 #315165
by royka
Replied by royka on topic Real-Time Kernel with Orange Pi 4 LTS
When you activate too many overlays they can interfere with each other, because some pins have multiple functions. Some can also cause extra interrupts, so remove everything that you don't need and isolcpus should be placed after extraargs:
verbosity=1
bootlogo=true
console=both
fdtfile=rockchip/rk3399-orangepi-4-lts.dtb
rootdev=UUID=a703d82e-8d61-4266-8b54-c10361d608ca
rootfstype=ext4
extraargs=isolcpus=2-5
overlay_prefix=rockchip
overlays=rk3399-opp-2ghz rk3399-spi-spidev rk3399-uhs
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
Last edit: 24 Nov 2024 12:51 by royka.
- Hossein74Majidi
25 Nov 2024 07:07 #315220
by Hossein74Majidi
The spi it's not found yet. I've enabled it in armbina-config menu but still there's no spidev in /boot/ directory.
just to be clear, here is my /boot/ directory:
root@orangepi4-lts:~# ls /dev/
autofs gpiochip2 log mmcblk0boot1 snd tty20 tty37 tty53 ttyS1 vcs5 vcsu7
block gpiochip3 loop0 mmcblk0p1 stderr tty21 tty38 tty54 ttyS2 vcs6 vga_arbiter
btrfs-control gpiochip4 loop1 mmcblk0rpmb stdin tty22 tty39 tty55 ttyS3 vcs7 vhci
bus hidraw0 loop2 mqueue stdout tty23 tty4 tty56 ttyS4 vcsa vhost-net
cec0 hidraw1 loop3 net tty tty24 tty40 tty57 ttyS5 vcsa1 video0
char hidraw2 loop4 null tty0 tty25 tty41 tty58 ttyS6 vcsa2 video1
console hidraw3 loop5 port tty1 tty26 tty42 tty59 ttyS7 vcsa3 video2
cpu_dma_latency hugepages loop6 ppp tty10 tty27 tty43 tty6 uhid vcsa4 video3
cuse i2c-0 loop7 psaux tty11 tty28 tty44 tty60 uinput vcsa5 video-dec0
disk i2c-1 loop-control ptmx tty12 tty29 tty45 tty61 uleds vcsa6 video-dec2
dri i2c-3 mapper pts tty13 tty3 tty46 tty62 urandom vcsa7 watchdog
ecryptfs i2c-4 media0 random tty14 tty30 tty47 tty63 usb vcsu watchdog0
fb0 i2c-7 media1 rfkill tty15 tty31 tty48 tty7 v4l vcsu1 wcn_op
fd iio:device0 media-dec0 rtc tty16 tty32 tty49 tty8 vcs vcsu2 zero
full initctl media-dec1 rtc0 tty17 tty33 tty5 tty9 vcs1 vcsu3
fuse input mem shm tty18 tty34 tty50 ttyBT0 vcs2 vcsu4
gpiochip0 kmsg mmcblk0 slog_wcn0 tty19 tty35 tty51 ttyBT1 vcs3 vcsu5
gpiochip1 kvm mmcblk0boot0 slog_wcn1 tty2 tty36 tty52 ttyS0 vcs4 vcsu6
and as you said, this is the content of my armbianEnv.txt:
verbosity=1
bootlogo=true
console=both
rootfstype=ext4
btw, during latency test and glxgears, the board has many lags and works so slow. is it normal?
Replied by Hossein74Majidi on topic Real-Time Kernel with Orange Pi 4 LTS
verbosity=1 bootlogo=true console=both fdtfile=rockchip/rk3399-orangepi-4-lts.dtb rootdev=UUID=a703d82e-8d61-4266-8b54-c10361d608ca rootfstype=ext4 extraargs=isolcpus=2-5 overlay_prefix=rockchip overlays=rk3399-opp-2ghz rk3399-spi-spidev rk3399-uhs usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
Aha I see, I tested what you said. The latency got better and it's 31.8 us, is it goo enough yet?just to be clear, here is my /boot/ directory:
verbosity=1
bootlogo=true
console=both
rootfstype=ext4
- royka
25 Nov 2024 13:50 - 25 Nov 2024 14:03 #315235
by royka
Weird that spidev doesn't show up, I think that the overlay is not complete, since it worked (or at least visible) before you could try to add the overlay files of the other boards to see if it helps.
The (gpu?) lag is probably because all the small cores are isolated now, you can try to see if the latency is still low enough with less cores isolated, isolcpus=3-5, isolcpus=4,5 or isolcpus=5. The first 2 cores are faster, so ideally you would isolate the second core, but then I think it should be changed in the source of LinuxCNC to run on that core instead of the last core, but 31.8us is certainly not bad
So you can try the following config:
verbosity=1
bootlogo=true
console=both
rootfstype=ext4
extraargs=isolcpus=4,5
overlays=rk3399-opp-2ghz rk3328-spi-spidev rk3399-spi-spidev rk3399-uhs rk3568-hk-spi-spidev
Last edit: 25 Nov 2024 14:03 by royka.
- Hossein74Majidi
26 Nov 2024 07:50 - 26 Nov 2024 07:54 #315279
by Hossein74Majidi
verbosity=1 bootlogo=true console=both fdtfile=rockchip/rk3399-orangepi-4-lts.dtb rootdev=UUID=a703d82e-8d61-4266-8b54-c10361d608ca rootfstype=ext4 extraargs=isolcpus=4,5 overlay_prefix=rockchip overlays=rk3399-opp-2ghz rk3328-spi-spidev rk3399-spi-spidev rk3399-uhs rk3568-hk-spi-spidev usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
Thanks. I did search for some overlays of spi of other devices but i couldnt find anything.
I changed the status of the spidev@0 in rk3399-orangepi-4-lts.dts and compile it again (it was status="disabled" and I changed it to "okay") but it didnt work. I have no idea what should I do
about the latency-test, it made it worse (50 us) and the lag in gpu just got better slightly.
Last edit: 26 Nov 2024 07:54 by Hossein74Majidi.
- royka
27 Nov 2024 01:58 #315336
by royka
It seems indeed that you have to enable the one that you need, so it's better to put back the original dit and download the dtbo source from:
raw.githubusercontent.com/armbian/build/...3399-spi-spidev.dtso
First remove the spi overlays from armbianEnv.txt
Check which spi goes to the gpio pins and isn't in use by anything else and recompile/install with: sudo armbian-add-overlay rockchip-rk3399-spi-spidev.dtso
For the slow graphics you could try to see if the GPU irq is on a cpu with many other interrupts and move to a less busy CPU: cat /proc/interrupts
50us should still be okay I think, although I'm not sure how this influences the spi connection, likely that it will need a more optimized driver
- Hossein74Majidi
28 Nov 2024 05:38 #315436
by Hossein74Majidi
This is the main spidev file in my board:
drive.google.com/file/d/1XAjIt_TSBaVCBum...S3D/view?usp=sharing
Thanks but it still doesnt work.It seems indeed that you have to enable the one that you need, so it's better to put back the original dit and download the dtbo source from:
- royka
28 Nov 2024 06:18 #315438
by royka
You didn't activate one of the spi numbers yet. So first open the dtso and replace ONE of the disabled to okay.
- Hossein74Majidi
28 Nov 2024 08:33 #315442
by Hossein74Majidi
Thanks a lot.
now when I run linuxcnc I get this:
Debug file information:
Note: Using POSIX realtime
Unexpected realtime delay on task 0 with period 1000000
This Message will only display once per session.
Run the Latency Test and resolve before continuing.
note: MAXV max: 25.000 units/sec 1500.000 units/min
note: LJOG max: 25.000 units/sec 1500.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
note: jog_order='XYZ'
note: jog_invert=set()
DRM_IOCTL_PANFROST_CREATE_BO failed: Invalid argument
/usr/bin/linuxcnc: line 977: 6721 Segmentation fault $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
6683
6717
Stopping realtime threads
Unloading hal components
and then it wont open anything. even the simulation cant be opened.
Yes that was the problem and also I needed to set its status to okay in rk3399-orangepi-4-lts.dtb in /boot/dtb/rockchip.You didn't activate one of the spi numbers yet. So first open the dtso and replace ONE of the disabled to okay.
Thanks a lot.
6683
6717
- royka
28 Nov 2024 09:22 #315444
by royka
Maybe an old mesa version? Are you using a recent image?
- Hossein74Majidi
28 Nov 2024 10:04 #315450
by Hossein74Majidi
I've installed linuxcnc 2.9.3 and the mesa flash is installed using clone and make installMaybe an old mesa version? Are you using a recent image?
Time to create page: 0.131 seconds
