Real-Time Kernel with Orange Pi 4 LTS
- Hossein74Majidi
02 Dec 2024 08:14 #315770
by Hossein74Majidi
Replied by Hossein74Majidi on topic Real-Time Kernel with Orange Pi 4 LTS
I did compile successfully:
- Debian Bookworm
- Kernel 6.12.1 Real-time
- Minimal without desktop
- SPI Configured as desired
It boots up ok and I've installed linuxcnc too. however linuxcnc can't be opened cause no desktop.
Now how can I add linuxcnc to the build system, in order for after compiling linuxcnc be already installed and when system boots up, linuxcnc shows up without any desktop gui.
- Debian Bookworm
- royka
- Thank you received: 135
02 Dec 2024 08:35 - 02 Dec 2024 09:35 #315772
by royka
Replied by royka on topic Real-Time Kernel with Orange Pi 4 LTS
With 6.12 the kernel needs a small patch to be recognized as realtime for linuxcnc and needs a specific config otherwise it gives an error during compiling:
forum.linuxcnc.org/38-general-linuxcnc-q...6-12?start=10#315437
And see the next post for the necessary config.
LinuxCNC needs X to start, you can try something like:
raspberrypi.stackexchange.com/questions/...hout-showing-desktop
Last edit: 02 Dec 2024 09:35 by royka.
The following user(s) said Thank You: Hossein74Majidi
- Hossein74Majidi
02 Dec 2024 10:24 - 02 Dec 2024 10:26 #315775
by Hossein74Majidi
After this, I used that patch that you said and I copied it to /patch/kernel/archive/rockchip64-6.12. However during this build I compiled it with XFCE Desktop. Now after compilation again it doesnt boot at all!!!
I'm trying to find out why it doesnt boot.
Or I can compile it without desktop (minimal) and install X to find out if the latency gets better or not.
Another thing that I did was, I added patch for 6.6.63 rt46 to my 6.6 kernel. but during the compilation I get some errors however it compiles without rt patch
I've done based on what you said about installing X, and desktop got enabled using start X and linuxcnc showed up. hwoever its latency was really bad, something like 500 us. which it was probably because of not being real-time (without adding the rt patch that you mentioned)With 6.12 the kernel needs a small patch to be recognized as realtime for linuxcnc and needs a specific config otherwise it gives an error during compiling:
Last edit: 02 Dec 2024 10:26 by Hossein74Majidi.
- royka
02 Dec 2024 10:41 #315776
by royka
Without seeing (uart) logs it's hard to tell what's going wrong.
With the 6.6 kernel likely you didn't remove the localversion part from the patch like I mentioned before. Probably you can also remove it from the kernel config menu.
If it's something else, you should provide logs
- Hossein74Majidi
02 Dec 2024 12:44 #315786
by Hossein74Majidi
but for bot kernels 6.12 and 6.6, when I tested the latency-test I got 0 for all of it parameters!!
(kernel 6.6 with rt patch from kernel.org and 6.12 with rt patch that you gave its link)
btw I installed linuxcnc using custompatch.sh file to be installed during the compilation, can it be the problem for this?
Yes, for kernel 6.6 it was the localversion indeed, I forgot about itWithout seeing (uart) logs it's hard to tell what's going wrong.
- royka
02 Dec 2024 13:16 #315787
by royka
As far as I know it shouldn't matter if you install it during compilation, otherwise it would be fixed with "apt reinstall linuxcnc-uspace".
What do you see with: uname -a ?
What do you see in the terminal when you start with: latency-histogram ?
- PatJac
02 Dec 2024 16:57 #315808
by PatJac
no go ,it's corrupted somehow .
A minimal img would be fine, less prone to those 5+Gb img corruption..
or tar.gz the huge thing .
I will give it another go .
Replied by PatJac on topic Real-Time Kernel with Orange Pi 4 LTS
Did not even succeded at installing the img...second try ,re sha checking now the one i got...@PatJac let us know the result you can get with the RK3399 board
- royka
02 Dec 2024 17:10 #315810
by royka
No problem, but you can also just install the dtb and kernel deb that I uploaded.
It doesn't boot or writing error?
- PatJac
02 Dec 2024 17:55 #315812
by PatJac
I am trying to work it out of opi4 minimal trixie 6.12 , as i got success that way with the opi5 .
i'll be back !!
i'll be back !!
- PatJac
02 Dec 2024 18:23 #315819
by PatJac
got bad sha checksum on all 2 download .
Time to create page: 0.153 seconds
