how to run PCIe Parallel Port in mode x with 9 inputs?
31 Jan 2025 04:18 #320203 by tommylight
I have this
forum.linuxcnc.org/18-computer/54368-pci...ut-of-the-box#313942
I can do some tests whenever i get to the shop and report back.
All built in parallel ports that i have tested worked in X mode, all were on used "enterprise" PC's from Dell, HP, Lenovo and Fujitsu.
Also did test one of the PCI cards in X mode and it worked with the above mentioned issue that it did require a bit more current to trigger, not sure of the exact one as i had over 10 versions.
The following user(s) said Thank You: sk_linuxcnc
Time to create page: 0.142 seconds
