[SOLVED]linuxcnc Latency test ambiguous results
1 year 6 months ago #327295 by MarkoPolo
Have you tried isolating the CPU cores?
I have the same processor, but a different motherboard, and the results are better.
It is possible that your problem is caused by something other than delays, but it is worth trying to improve the result.
The following user(s) said Thank You: DarkPhoinix
1 year 6 months ago - 1 year 6 months ago #327300 by DarkPhoinix
I was just going down that road, I found a post where it was talked about, For now I did this:
BOOT_IMAGE=/boot/vmlinuz-6.1.0-33-rt-amd64 root=UUID=e5282ae9-3e96-4f4e-9c6c-19b3dd421c80 ro initrd=/install/gtk/initrd.gz quiet isolcpus=1,2 r8168.EEE=0 pcie_aspm=off nohz_full=1,2
but I would like to try to add: rcu_nocbs
can you share your lspci result?
Last edit: 1 year 6 months ago by DarkPhoinix.
1 year 6 months ago - 1 year 6 months ago #327302 by DarkPhoinix
this is with my new kernel parameter. Youtube and stress test on.
1 year 6 months ago #327306 by MarkoPolo
I have these kernel parameters set "quiet isolcpus=2,3 acpi_irq_nobalance noirqbalance irqaffinity=0 processor.max_cstate=0 intel_idle.max_cstate=1"
From what I remember, better results are when you isolate 3rd and 4th core.
The "stress" test should not affect core 3 and 4.
1 year 6 months ago - 1 year 6 months ago #327308 by DarkPhoinix
You have integrated VGA i have a NVIDIA 610 i think is this the cause of high latency , my motherboard don't have vga output!
can you try use Rustdesk remote desktop with youtube video and try another time latency test?
1 year 6 months ago #327331 by MarkoPolo
I don't use remote desktop. I did a test with three working youtube videos
Time to create page: 0.154 seconds
