[SOLVED]linuxcnc Latency test ambiguous results
1 year 6 months ago #327423 by DarkPhoinix
 28:          0          0          0         18  IR-PCI-MSI 360448-edge      mei_me  cat /etc/modprobe.d/mei* blacklist mei blacklist mei_hdcp blacklist mei_me
Very nice next blacklisted intel backdoor! six windows of youtube no junction error!! But nest use rustdesk error coming
1 year 6 months ago #327433 by PCW
Did you try pinning the Ethernet IRQ to the last processor?
This usually make a large difference in Network latency
The following user(s) said Thank You: DarkPhoinix
1 year 6 months ago #327440 by DarkPhoinix
With your script the irq go to 2,3 core!
 26: 0 0 39646 4301 IR-PCI-MSI 1572864-edge enp3s0
1 year 5 months ago #327490 by DarkPhoinix
I can't move IRQ on just core 3, it stays between 2 and 3.
I created 2 startup scripts that do nothing but move irq at startup to be sure I used smp_affinity_list + smp_affinity but nothing core 2 always has to do with IRQ 26! Does anyone know a way to move it? Change kernel version? Now I'm with 6.1. 0-33-rt-amd64 in theory with an upgrade I should have 6.1. 0-34-rt-amd64 but I don't think it solves the problem.
1 year 5 months ago #327491 by DarkPhoinix
 while true; do cat /proc/interrupts | grep enp3s0; sleep 1; done  26:          0          0        123       5373  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5416  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5464  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5512  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5560  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5608  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5656  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5704  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5752  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5812  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5872  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5920  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       5968  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6016  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6064  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6112  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6173  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6221  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6269  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6317  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6365  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6413  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6461  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6509  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6569  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6641  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6689  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6737  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6785  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6833  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6912  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       6960  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       7008  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       7070  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       7118  IR-PCI-MSI 1572864-edge      enp3s0  26:          0          0        123       7166  IR-PCI-MSI 1572864-edge      enp3s0
Is it working? I don't understand what cat /proc/interrupts does maybe there are old values ​​before the switch to core 3?
1 year 5 months ago #327506 by PCW
That looks like its working since you are only getting interrupts on CPU 3
(CPU 2 interrupt count  is not changing)
Time to create page: 0.079 seconds
