[SOLVED]linuxcnc Latency test ambiguous results
1 year 6 months ago - 1 year 6 months ago #327232 by DarkPhoinix
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 09)
I need search and compile him or only apt-get?
Last edit: 1 year 6 months ago by DarkPhoinix.
1 year 6 months ago #327233 by PCW
The following user(s) said Thank You: DarkPhoinix
1 year 6 months ago #327242 by DarkPhoinix
I have a nvidia 610 video card, should I replace nouveau with the proprietary nvidia driver? (I already did it in theory)
1 year 6 months ago #327244 by PCW
I don't think the video is an issue as it would show up in the generic latency tests.
1 year 6 months ago #327246 by tommylight
NVIDIA proprietary drivers do not work with RT kernel and neither do new AMD drivers.
Most of the time NVIDIA cards will cause latency spikes and should not be used for machine control, but i have plenty of GTX1060 and GTX1070 that are usable with NOVEAU drivers, older ones will mess latency badly, and even the ones i have on some motherboards do cause issues, so it's a cr@p shoot.
First, fix the ethernet latency, disable power saving options in BIOS and hyperthreading and TPM and..., then we can see what still needs to be done.
1 year 6 months ago - 1 year 6 months ago #327248 by DarkPhoinix
installed [code]r8168:
ping -c 4 -i .2 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=255 time=0.298 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=255 time=0.308 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=255 time=0.273 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=255 time=0.273 ms
--- 10.10.10.10 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 610ms
rtt min/avg/max/mdev = 0.273/0.288/0.308/0.015 ms
chrt 99 ping -i .001 -q -c  60000 10.10.10.10
60000 packets transmitted, 60000 received, 0% packet loss, time 59999ms
rtt min/avg/max/mdev = 0.178/0.253/0.441/0.031 ms
no packet loss this time with r8168!! thanks !
i have system with the nvidia proprietary driver i need to go back to nouveau?
Time to create page: 0.422 seconds
