Which kernel version is best for real time?
08 May 2025 14:47 #327994 by DarkPhoinix
Which kernel version is best for real time? was created by DarkPhoinix
I tried several times even asking for help to solve the latency problems even by changing the video card.
I opened a post here:
forum.linuxcnc.org/38-general-linuxcnc-q...st-ambiguous-results
So I decided to do it my way and not Debian's way.
www.kernel.org/
I have always used Debian but as always this time I will have to compile the kernel by hand, hoping that there are not too many changes since the last time I did it, but I doubt it.
Can anyone please tell me which kernel is best for RT?
Thanks a lot.
08 May 2025 15:46 - 08 May 2025 16:03 #328010 by DarkPhoinix
Replied by DarkPhoinix on topic Which kernel version is best for real time?
Perhaps try this:
Save your config files somewhere very safe.
Open your PC and remove all unnecessary hardware (except the GPU).
Reinstall LinuxCNC from the official ISO. (The latest version, or perhaps some earlier version).
Set CPU governor to performance.
Run latency test.
See if latency is improved.
Changing the scaling govenor to performance reduced my latency a noticable amount.
Now i try
echo performance | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor
in my bios conf i have:
Enhanced Intel SpeedStep Technology: Disabled
Turbo Mode: Disabled
CPU C3 Report: Disabled
CPU C6 Report: Disabled
i need to enable all for change governor?
i have another SSD ready with same version of linuxcnc 2.9.4 i try to install kernel 6.6 for test, make monolithic for first if see error go modular kernel with initrd image with SATA driver in.
Last edit: 08 May 2025 16:03 by DarkPhoinix.
08 May 2025 22:12 #328033 by unknown
Replied by unknown on topic Which kernel version is best for real time?
Yes there are some changes to the 6.x series kernel. A couple of months ago there was a long thread regarding building the newer kernels. You would be best to search for that thread and read it, pay special attention to the posts by royka. His advice was crucial in building the RPi5 & RPi4 for the Linuxcnc images.
You have to make sure that you select the proper RT kernel in the config.
Some kernel require a patch so that Linuxcnc recognises that there is a RT kernel running.
The kernel provided with the 2.9.5 iso works, is stable and is in use by many users with no issues.
The following user(s) said Thank You: DarkPhoinix
09 May 2025 08:29 #328050 by DarkPhoinix
Thank you for the info today I will spend time compiling various kernels on my PC and I will try them!
I also answered you in the other post!
09 May 2025 10:48 #328052 by DarkPhoinix
i dont find  linuxcnc 2.9.5 iso, you have a link?
09 May 2025 11:27 #328054 by unknown
Sorry I meant 2.9.4
Try not to get bogged down with latency.
Test the machine running code, if it works don't worry too much about it.
I took the gcode file that loads when you first start Axis, made it into a loop, loops thru the gcode about a hundred times,if I don't get any errors I'm confident it will be fine.
I really don't think there will be much difference between a modular or monolithic kernel.
You can gain a bit by fiddling with mount options, looking for any background services that aren't needed, I generally disable sound and I'll disable wifi if it's not required.
You'll find this forum a lot different to cnczone, for one no one on here gets caught playing my rapids are this fast, also you won't here anyone saying that you need to be a programmer to use Linuxcnc. It works and works well.
Almost any issues you have will have been discussed many many ten times over.
99.99% of the reason Linuxcnc won't start is a typo somewhere in the hal & ini files.
Sometimes I think that running the latest kernel on older CPUs isn't the best course of action. Far better to have some extra latency and a stable system.
Look you can spend a lot of time building different kernels and trying all the tricks in the book to lower latency, but as long as latency is, as a rule thumb, below 100,000 ns for an external step/direction generator you're good to go.
Then again network latency can be a PITA to sort sometimes.
09 May 2025 11:41 #328056 by DarkPhoinix
Why in the kernel of linuxcnc why are hibernation and other acpi function active?
Is not  a problem?
09 May 2025 11:46 #328057 by DarkPhoinix
Warning: Spoiler!
Yes i have Realtek card but i solved the problem with the r8168-dkms module.
09 May 2025 12:01 #328060 by DarkPhoinix
root@cnc:/home/cnc/kernel/linux-6.12.27# cat .config | grep -i Preempt
# CONFIG_PREEMPT_NONE is not set
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
CONFIG_PREEMPT_RT=y
CONFIG_PREEMPT_COUNT=y
CONFIG_PREEMPTION=y
CONFIG_PREEMPT_RCU=y
CONFIG_HAVE_PREEMPT_DYNAMIC=y
CONFIG_HAVE_PREEMPT_DYNAMIC_CALL=y
# CONFIG_DEBUG_PREEMPT is not set
# CONFIG_PREEMPT_TRACER is not set
# CONFIG_PREEMPTIRQ_DELAY_TEST is not set
ok?
09 May 2025 17:50 #328090 by unknown
Not quite true, disabling hyper threading is well worth it, as are a number of other generic options that have been discussed.
As for the kernel config, the most important settings are the preempt_rt ones, infact one of the easiest ways is to base the config for the new kernel on the running one.
If you really feel the issue is with the GPU I don't think a different kernel will fix much.
