You should be able to use your existing end switches as home switches and limit switches. It is so much easier if set up completely. Just make sure you have a home_offset to move the axis away from the limit switch (even 0.5mm is enough, sometimes less). Otherwise the limit switch will trigger as homing completes.Dear members,
my Leinen FM1 is now running with LinuxCNC on all 4 axes.
I have built a small cubicle containing the required components. I have not modified the original setup at all. The CNC cubicle can be activated by a simple changeover of the original plugs coming from the mill (HONDA MR 50 pin and 20 pin plugs and the 4 Heidenhain plugs) from the original control panel to the CNC cubicle.
The relevant hardware I'm using is
- MESA 7i97T
- 1 Heidenhain EXE with 3 channels from a MAHO mill (1 my resolution)
- 1 Heidenhain EXE 610 for the rotary axis (0,001° resolution)
- 2 Mattke two channel Tach DC motor controller MTRG 25/2D
- 1 Mattke MTRM 061/5 Tach DC motor controller for the spindle motor
- 1 cycloidal transfer 60VAC for the spindle
- 1 cycloidal transformer 2 x 22VAC for the axes motors
- 1 5VDC and 1 12VDC power supply
- 1 All-In-One PC
Only the MESA card is new. All the other other equipment is bought second hand and mostly about 40 years old. But it works !
To be sincere, without help I would not have been able to configure LinuxCNC.on my own. A very kind and knowledgeable member of this forum did this work for me. Thanks a lot to him.
If anybody needs the INI and the HAL files, I would be happy to send a copy.
The following functions are implemented::
- x-, y-, z- and rotary-axis control
- end switches for the 3 linear axes
I have and I need no homing function.
The spindle speed is controlled outside LinuxCNC with an old Beckmann 10-turn potentiometer. I know them from the 80th of the last century, using them in the university labs.
Furthermore I have installed an original old style Waldmann machine light
Best regards
Hartwig
