getting started , latency and breakout board questions
- Thank you received: 7488
28 Aug 2025 00:55 #334016
Replied by tommylight on topic getting started , latency and breakout board questions
There was a reason that apparently now does not exist, so feel free to install it on the hard drive from the USB.
And yes, you can make as many configs as you like for the same machine, like have a slower config for when stuff can not fail, or a very high speed one where you can adjust sliders and actually test how fast you can push the machine before it fail, or ... turn RGB light on.
- Chock
28 Aug 2025 01:46 #334019
by Chock
Replied by Chock on topic getting started , latency and breakout board questions
thanks Tommylight. ok I will work on transferring to the hard drive. But probably not rite away. Currently i am having trouble adding the next axis. Some kind of Clearpath initialization problem; as the problem is only with the new servo.
Also i need to work on the Estop, and the hardware cabinet
thanks i will just deal with the re config issue until i learn a bit more about what i am doing
Time to create page: 0.146 seconds
