Stepper online A6 Servo motor as Spindle motor
1 year 1 day ago #337566 by Hakan
Here it looks fine. Saw it in the first ethercat-conf.xml you attached.
There is no reason the PV mode should cause problems with other drives.
Check the output of "sudo dmesg" the last say 20 lines are of interest.
1 year 1 day ago #337571 by Will_cnc
here is the result of running sudo dmesg
[ 4.057274] Bluetooth: HCI UART protocol Broadcom registered
[ 4.083683] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.087327] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.087734] usbcore: registered new interface driver brcmfmac
[ 4.291603] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[ 4.291861] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Apr 15 2021 03:03:20 version 7.45.234 (4ca95bb CY) FWID 01-996384e2
[ 4.393502] Bluetooth: hci0: BCM: chip id 107
[ 4.393719] Bluetooth: hci0: BCM: features 0x2f
[ 4.394870] Bluetooth: hci0: BCM4345C0
[ 4.394873] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0000
[ 4.426812] Bluetooth: hci0: BCM4345C0 'brcm/BCM4345C0.hcd' Patch
[ 4.462459] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[ 4.462471] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 4.469213] pps pps0: new PPS source ptp0
[ 4.469263] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[ 4.470153] warning: `iwconfig' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 4.470300] ec_master: loading out-of-tree module taints kernel.
[ 4.470306] ec_master: module verification failed: signature and/or required key missing - tainting kernel
[ 4.475936] EtherCAT: Master driver 1.6.8 1.6.8.g2543cc5-1+27.1
[ 4.476617] EtherCAT: 1 master waiting for devices.
[ 4.490862] zram: Added device: zram0
[ 4.628070] ec_generic: EtherCAT master generic Ethernet device module 1.6.8 1.6.8.g2543cc5-1+27.1
[ 4.628086] EtherCAT: Accepting 2C:CF:67:24:E6:CD as main device for master 0.
[ 4.628096] ec_generic: Binding socket to interface 2 (eth0).
[ 4.645137] EtherCAT 0: Starting EtherCAT-IDLE thread.
[ 4.747291] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 4.747296] Bluetooth: BNEP filters: protocol multicast
[ 4.747300] Bluetooth: BNEP socket layer initialized
[ 4.752789] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 5.129671] Bluetooth: hci0: BCM: features 0x2f
[ 5.131033] Bluetooth: hci0: BCM43455 37.4MHz Raspberry Pi 3+
[ 5.131037] Bluetooth: hci0: BCM4345C0 (003.001.025) build 0342
[ 5.131328] Bluetooth: hci0: BCM: Using default device address (43:45:c0:00:1f:ac)
[ 5.150144] Bluetooth: MGMT ver 1.23
[ 5.155700] NET: Registered PF_ALG protocol family
[ 6.530993] macb 1f00100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 6.537016] EtherCAT 0: Link state of ecm0 changed to UP.
[ 6.545022] EtherCAT 0: 4 slave(s) responding on main device. Re-scanning on next possibility.
[ 6.545024] EtherCAT 0: Slave states on main device: PREOP.
[ 6.545025] EtherCAT 0: Re-scanning now.
[ 6.545194] EtherCAT 0: Scanning bus.
[ 7.356283] EtherCAT 0: Bus scanning completed in 808 ms.
[ 7.356289] EtherCAT 0: Using slave 0 as DC reference clock.
1 year 1 day ago #337572 by Hakan
Looks fine so far.
Can you start linuxcnc to see if any useful message comes out to explain jerkiness.
You can also try to temporarily remove/comment out the dcconf line for the spindle driver only in the ethercat.conf.
1 year 1 day ago #337573 by Will_cnc
Having tested the machine this morning , the Juddering on the servo drives appears too of stopped for the time being?
Could it be due to the pi not being powerful enough and having bad latency? Yesterday I had a few windows open running whilst running linux .
If this is the issue is it worth upgrading from the pi5 to something with more powerful ? .
Any suggestions on reasonable priced upgrade options
1 year 1 day ago #337580 by Hakan
Sounds good. Let's hope it keeps that way.
I ran the RPi4 for some time and it was ok, so the Rpi5 should be ok too?
Latency isn't so much of an issue now with the "-" sign.
That "should" keep it on track (sync).
You can check if it isn't doing so great with the value of the pin lcec.0.pll-reset-count
If that is way above 1 there may be a problem.
First thing to do then is to increase lcec.0.pll-step to 10000 which is max, or something in between say 5000,
setp lcec.0.pll-step 10000
If pll-reset-count then keeps increasing you need to work on the latency.
The main reason I switched to Intel-based is that the gui became more and more
sophisticated and needed more and more processing power to function smoothly.
I am hesitant to recommend a setup, there are many that works fine.
For ethercat I would definitely look for an Intel network adapter,
the rest is more form factor, power draw, cpu performance.
I have had good luck with the N100/N150 mini pcs. Intel network adapter though.
Time to create page: 0.424 seconds
